JBL Stage 135C Review (Center Speaker)
Rate this speaker:
    Votes: 168 88.4%
    Votes: 20 10.5%
  • 3. Fine (happy panther
    Votes: 2 1.1%
    Votes: 0 0.0%
voodooless
Netherlands
You don't need to measure them. One look is enough to know that they will not work. A d'Appolito design on its side will always create a narrow horisontal dispersion.
That really depends on the x-over frequency, doesn't it? For a 3-way with vertical TM and horizontal W alignment, you'll want to have the woofer X-over as low as possible, so that the TM mostly dictates the directivity. The Emotiva uses 550 Hz, probably still too high to fully mitigate the effect. But that 3" woofer might not handle much lower either.
MZKM
Land O’ Lakes, FL
Strange that we haven't seen more of this budget center channels with a BMR center driver, eventually waveguided, plus cheap small format tweeter depending on the BMR ... seems a cheap and effective way to get much better directivity behavior in a much wider range and speech region in a low cost, low height enclosure, avoiding an expensive quality coax or a larger box to cram a bigger midrange+tweeter in the center.
Limited loudness probably depending on where you crossover too, but at the budget sector or smaller rooms that is a minor sin compared to this mess...
Well, for the ones that Dennis Murphy uses, the sensitivity is like 85dB, and Dennis stated they cannot be run dual to increase sensitivity, only to increase max power handling.
sarumbear
Can you share what makes or breaks such designs? Examples of successful ones maybe?
As I said, horizontally aligned tweeter and woofer/mid will always create a limited dispersion.
Find a d'Appolito type 2-way speaker, check its Spinorama in the vertical. Notice how narrow it is. Now turn that speaker 90 degrees in your head. The narrow dispersion is now in the horisontal.
sarumbear
We are talking 2-way here. 3-way will always have the tweeter and mid range vertically aligned.
sarumbear
I agree with you. That's why all the posts acting shocked at these results are strange. It is clear from the driver layout that the A135C will have narrow horizontal dispersion. It does not follow logically that all center speakers suck and no center speaker can be designed to have good performance at a competitive price.
The problem is the height limitation. I can safely say that no correct centre speaker can be designed to fit into a 12-15cm height. The smallest tweeter will have at least 8cm height by itself.
abdo123
Brussels, Belgium
when you say limited dispersion do you mean what we see here? or is it more controlled?
sarumbear
abdo123
Brussels, Belgium
Limited = narrow
you mean like this
or like this
Because there is a big difference. I'm trying to figure out if ANY D'appolito design out there can be considered Hi-Fi or not.
HooStat
Calabasas, CA
I have been meaning to put together a list of all of the "seemingly appropriately designed" center channels, including 3-way center channels and 2-way or 3way speakers that use concentric drivers. It isn't a long list, but it is bigger than one might think. KEF center channels plus most of their monitors, Monitor Audio, some Revel, Emotiva, SVS, Elac, Genelec Ones, Neumann KH310, Kali, some Dynaudio pro monitors, etc. I am sure there are a lot more.
nick-v
I despair...
But it can be done. Here is my secondary system.
I did the same thing in my master bedroom system.
Rather than hacking up the studs to install a "traditional" horizontal center channel, I installed a beefy 3-way vertically oriented center channel. Much higher performance!
sarumbear
you mean like this
or like this
The top one has a smooth FR gradually narrowing but still flat for +/-50 degrees. On the bottom one FR changes dramatically between 1KHz and 3kHz when you move left and right.
voodooless
Netherlands
Are we? You were reacting to the Emotiva design, which is a 3-way with vertical TM.
There is a way though to have the 2-way MTM design work a bit better, either with a 2.5-way or by making one of the woofers a passive radiator.
sarumbear
I am reacting to the review! :facepalm:
There is a way though to have the MTM design work a bit better, either with a 2.5-way or by making one of the woofers a passive radiator.
An MTM will never work for a centre speaker! Show us how if you have a way.
beaRA
Yep. If you care about horizontal dispersion, then you better find a way to accommodate at least 18cm (7in) for something like the Kef Q150. Anything shorter than that and the customer cares more about the form factor than the performance. Clearly these big manufacturers consider that a valid market segment.
sarumbear
That is why I said Harman should be leading the industry. Otherwise, keep manufacturing a type of speaker that doesn't work is not dissimilar to selling audiphool products.
voodooless
Netherlands
That’s not what the post was about ;)
I said a bit better. Trick is to not let the second woofer play the midrange. You’ll still have some directivity error to horizontal alignment, but it will be much better than a traditional MTM.
KxDx
Tidewater Virginia
The HSU CC-8 could be used for a center, but it's a fairly big speaker at 10.5" on its side.
It would also have to have the highs EQ'ed down for center use.
sarumbear
How do you choose who will be sitting at the good side next to you? :)
