KEF R3 Speaker Review
laurelkurt
Rochester, NY
Pure conjecture based in my own ignorance, but perhaps vertical reflections? The M16's 2kHz-4kHz dip in his room measurement mirrors it's vertical dispersion graph, perhaps suggesting he's picking up a lot of floor and ceiling reflections (mostly floor). As the R3 has a lot more vertical energy he's similarly picking up a lot of positive reinforcement from both planes in its measurement.
And I'm assuming a hard concrete floor in a garage.
tuga
Oxford, England
Unless I am misunderstanding you @QMuse, you do not want to gate the impulse response in this case. Gating it turns just turns it into a quasi-anechoic measurement. Amir was looking to see how the PIR matches the actual in-room curve.
Is there any contraindication to using steady-state pink noise analysis?
ROOSKIE
Minneapolis
I'd suggest, KEF being British and all, that they're tuned for typical British rooms where they will likely be close to the front wall. Indeed KEF bookshelf speakers I have tried seem rather lean unless they are reasonably close to the wall. The other observation I'd make, is that once the bass is brought into balance in this way, they tend to sound rather polite at the high end.
Been wanting to say this about bass tuning but I kept forgetting. Thank you!! Yes, much smaller room sizes for many folks over there. Yes many here have that as well, but a number of our systems are tuned for very large living spaces.
This is why there is not a one size fits all way to asses bass response. Some speakers are designed to be 1 or 2 feet from the rear Wall and other more like 4-6 feet. Additionally many systems are designed not to be toed in (such as KEF and Dali) so on axis measurements are not design correct.
Anyway.
Fone
I heard these with a subwoofer in a store and really liked them.
I have heard the similar KEF LS50 probably a dozen times and like the driver engineering and style. But I thought they sounded rather mediocre.
I have made a breakthrough in finding the conflicting subjective listening tests to objective data. It opens a huge can of worms though so I need to do more testing to confirm hypothesis. For now, I can make the R3 sound almost as gorgeous sounding as M16 with a simple hack.
For now, the science is mostly correct. As was my subjective listening tests.
All the guesses here including mine were wrong. :) At least not the high order effect. In hindsight though, it is an obvious thing.
mi-fu
New York
Looking forward to it!
goldark
Don't tease us like this!
goldark
Well, the alternative was to let you all keep speculating/accusing me of being deaf. :D
Would this affect all previous speaker reviews potentially? (in terms of the subjective listening impressions)
Probably although more so the far field tests.
napilopez
NYC
Hmm. Wall distance? Toe in? SPL? Room nodes?Whether or not you were eating a brownie sundae while listening?
BYRTT
Denmark (Jutland)
$5 on a bottle of wine
Will put mine $5 reason is for far field a critical or picky listener needs them speakers that on axis have a shelved down contour in lowest octave moved closer to frontwall so they get a natural close enough boundary surface to try fill up that natural missing shelved down lowest octave, PIR curve should benefit that low end boost also because many listeners are often told to be more or less some bass heads ...:D
Thomas_A
Sweden
Sorry guys, I loaded wrong PIR for M16. :facepalm:
Here's how they look when range 1khz-10kHz is matched:
I can see that the proportion/level of the 1-2 kHz range vs the 2-5 kHz range is opposite in these two speakers. I guess that one thing that makes the presentation, at least in a stereo setup ("error correction" according to Shirley et al). I know what I prefer, and that is a bit higher level 1-2 kHz vs 2-5 kHz. It would be interesting to hear what the subjective evaluation would be if the R3 would be EQued to the same response as the Revel in the 1-5 kHz region.
