M-Audio BX8 D3 Monitor Review
Rate this studio monitor
    Votes: 7 4.1%
    Votes: 38 22.5%
    Votes: 109 64.5%
    Votes: 15 8.9%
This is a review, listening tests and detailed measurements of the M-Audio BX8 D3 studio reference (active speaker). I purchased it new from Amazon June of last year for $503. It seems discontinued now.
Look and feel is excellent. There is rubberized paint around the drivers which gives the unit a luxury feel. The cabinet is quite large and sturdy. Back panel is simplicity in itself:
Amplification is class AB (80 watts for woofer, 70 watts for tweeter) which is surprising. Good news is that this brings silence to the tweeter as I could barely hear a hiss with my ear next to it.
Nicely formed waveguides should produce good directivity.
Testing was performed using Klippel Near-field Scanner (NFS). Temperature was around 57 degrees F. Reference axis was the center of the tweeter.
M-Audio BX8D3 Measurements
As usual, we start with our anechoic frequency responses per CEA-2034/ANSI standard:
That sudden resonance at 590 Hz stands out well in addition to somewhat wavy response above it. On the positive front, bass extension is quite good especially given the size and cost of this speaker. There is usable bass down to some 40 Hz! Near-field measurements show that the kink at 590 Hz is the property of the woofer:
M-Audio BX8 D3 Studio Monitor Speaker near field Frequency Response Measurements.png
I expected it to be port resonances but those are quite subdued until you get to about 1 kHz. If someone has a better guess, please chime in.
Early reflections and predicted in-room simulations are for far field use so likely not very applicable in this application:
M-Audio BX8 D3 Studio Monitor Speaker early reflection Frequency Response Measurements.png
M-Audio BX8 D3 Studio Monitor Speaker PIR Frequency Response Measurements.png
I was very impressed with the low distortion, especially in bass at 86 dBSPL:
M-Audio BX8 D3 Studio Monitor Speaker Relative THD Distortion Measurements.png
As predicted, directivity and hence beamwidth uniformity is very good in horizontal axis:
M-Audio BX8 D3 Studio Monitor Speaker Horizontal directivity Measurements.png
Vertical suffers from typical issues with 2-way speakers but there seems to be good control even in that axis:
Here is our waterfall and step responses:
M-Audio BX8 D3 Studio Monitor Speaker CSD Waterfall Response Measurements.png
M-Audio BX8 D3 Listening Tests
The uneven frequency response had pre-biased me negatively going into the listening tests. But 5 seconds of listening to my standard test tracks changed my mind and quickly! That deep bass and clean output at that, brings a ton to the table. Speaker sounds like a much bigger one. Frankly I could have lived with the out of box response but still, took a shot at correcting the response with EQ:
The correction for the bass resonance should be self-explanatory. I then attempted to fill in the gap between 1 and 2 kHz but that resulted in extra brightness. Instead, I opted to pull down the hills in the next two regions. With all the filters in place, the difference was small but I thought it was more balanced and less brilliant/brittle.
The excellent bass response translated to my "speaker killer" tracks with sub-bass response down to 20 Hz. Many bookshelf speakers fall apart and produce distorted sound there (or none at all). The BX8D3 was different. It simply played those at lower volume but still clean. No doubt this contributed to my impression of the speaker sounding so clean.
While listening to only one speaker, I could easily fill my massive space with plenty of volume withy nary a hint of distortion or speaker/amp funning out of breath. The sound had authority and was quite enjoyable.
I was pretty depressed going into this review with first finding out the BX8 D3 is now discontinued. And then seeing response anomalies. Then I listened to the speaker and that changed my perspective. Not that the subjective impression was different from objective. It was not. You just had to go back and look again, noticing the bass extension and very low distortion. Research shows that 1/3 of our impression of a speaker sound comes from bass and boy was that true in this case. With a bit of EQ you have one impressive sounding studio monitor here which would be good at $500 but far better at the discount prices I see on clearance (as low as $118 on one site!!!).
Note that the extra bass means is that the BX8D3 will charge the room modes so you better have EQ especially if your room is small. Other monitors in its size which lack bass won't be similarly situated.
I am going to put the M-Audio BX8D3 on my recommended list. It is a shame that it is discontinued.
  • M-Audio BX8 D3 Frequency Response.zip
By the way, there are a number of "BX8" speakers for sale out there but seem to be another series with round waveguide rather than the square one in the model I tested.
Maiky76
French, living in China
Here is my take on the EQ.
Please report your findings, positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 5.2
With Sub: 7.2
Spinorama with no EQ:
  • LF Driver issue too bad...
  • Decent design buried some under tuning idiosyncrasies
  • Decent directivity will help for effective EQ
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 5.8
with sub: 7.8
Score EQ Score: 6.1
with sub: 8.2
Code:
M-Audio BX8 D3 APO EQ LW 96000Hz
April142023-124610
Preamp: -2.8 dB
Filter 1: ON PK Fc 64.51,    -1.53,    3.27
Filter 2: ON PK Fc 117.71,    -1.47,    1.55
Filter 3: ON PK Fc 645.12,    -3.11,    4.13
Filter 4: ON PK Fc 922.00,    -1.55,    2.14
Filter 5: ON PK Fc 1799.79,    2.50,    0.82
Filter 6: ON PK Fc 2979.36,    -1.86,    4.75
Filter 7: ON PK Fc 12256.79,    2.94,    0.55
Filter 8: ON PK Fc 9514.76,    -1.80,    4.14
M-Audio BX8 D3 APO EQ Score 96000Hz
April142023-124611
Preamp: -2.7 dB
Filter 1: ON PK Fc 63.50,    -1.48,    4.13
Filter 2: ON PK Fc 117.21,    -1.51,    1.21
Filter 3: ON PK Fc 625.78,    -2.90,    4.98
Filter 4: ON PK Fc 932.00,    -2.00,    1.81
Filter 5: ON PK Fc 1665.60,    2.96,    1.14
Filter 6: ON PK Fc 2929.12,    -1.46,    5.00
Filter 7: ON PK Fc 12251.29,    2.18,    0.71
Filter 8: ON PK Fc 9511.76,    -1.65,    3.17
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
some improvements
The rest of the plots is attached.
  • M-Audio BX8 D3 APO EQ Score 96000Hz.txt
  • M-Audio BX8 D3 APO EQ LW 96000Hz.txt
GD Fan
NY, NY USA
Agreed. The FR is kind of chewed up, looks like the bass extension was the saving grace.
3125b
Germany
Not too bad for 129€/piece, would have expected worse from the cheapest of the 8“ monitor crowd.
I would see this more as something cheap for casual listening rather than a serious monitor. They‘re fine without a sub for TV sound or something like that.
TonyJZX
yeah i think these are cheaper outside of the US strangely enough
in US its like $500 us for a single unit??? $1,000 for 2? at that price the competition is too stiff
where I am we can easily find a pair for $500 aud which is about $350 usd and we also have 10% sales tax here
at 129 euros its a no brainer
where else can you get a set of 8" powered for 260 euro?
my thinking is that the distributors here bought too many 8" units and few people want 8" units in their face (so to speak!)
they can easily sell 4-5-6" and so they have to discount 8" speakers
again, none of this is acceptable at $1,000 usd but for $260 euro? its this or simon and garfunkel's the sound of silence
btw. here's a pic of round tweeter version:
i feel like they substitutes parts but dont bother to change any specs sheets because... audience doesnt care
Tom C
Wisconsin, USA
Personally, I’d rather not have this playing below 600 or 700 Hz. And 6KHz to 10 KHz is not stellar. The off-axis behavior is reasonable. I wouldn’t want to pay list. Too many better alternatives. At ca.$120 it’s best to grab it fast. Give it to the kids. With a sub that plays to 500Hz.
thewas
Not great performance especially if it costed $500, but for later prices around hundred something acceptable as due to its decent directivity behaviour it can be improved via equalisation.
TonyJZX
i sort of feel like that defeats the purpose of an 8" woofer. if you're gonna cut at 500hz then get a smaller speaker?
590hz resonance is probably internal box wall reflection. More acoustic damping material would probably take care of it.
Yeh, looking through the port I can't see any stuffing....
Adi777
They probably sound much better than my Edifier S3000 Pro. Maybe buy a pair out of curiosity?
What sound source would be solid and sufficient for such speakers?
CrustyToad
Thanks amir for the review
At 129 euro from a reputable store this is quite a bargain since it takes well to EQ. Some competition for the JBL with more bass and a different overall response
Good to have options xD
pierre
Switzerland
I built an EQ for this speaker. Preference score goes from 5.2 to 6.1 with EQ and from 7.2 to 8.0 with EQ and a perfect subwoofer.
PIR and LW get significantly flatter. The EQ is limited to Q<3 and does track relatively well but miss a few peaks. I expect this speakers
to have high variability unit to unit so it doesn't really matter. Histograms are useful to see improvements both full range and on the midrange.
Code:
EQ for M-Audio BX8 D3 computed from ASR data
Preference Score 5.25 with EQ 6.11
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.21
Dated: 2023-04-14-09:11:46
Preamp: -3.7 dB
Filter  1: ON PK Fc  1724 Hz Gain +2.99 dB Q 1.32
Filter  2: ON PK Fc    69 Hz Gain -1.76 dB Q 2.96
Filter  3: ON PK Fc 15933 Hz Gain +2.42 dB Q 0.62
Filter  4: ON PK Fc   121 Hz Gain -1.31 dB Q 1.31
Filter  5: ON PK Fc   639 Hz Gain -2.81 dB Q 3.00
Filter  6: ON PK Fc   233 Hz Gain +0.94 dB Q 0.07
Filter  7: ON PK Fc  2938 Hz Gain -1.19 dB Q 2.87
Filter  8: ON PK Fc   861 Hz Gain -1.02 dB Q 2.73
Filter  9: ON PK Fc  9351 Hz Gain -1.51 dB Q 2.95
Waxx
Wodecq, Hainaut, Belgium
I don't see it's discontiued actually, not on the M-Audio site, and not in stores in europe. And here it's very cheap: https://www.thomann.de/be/m_audio_b...LCJjdXJyZW5jeSI6MiwibGFuZ3VhZ2UiOjJ9&reload=1
And in other stores it's also on stock, or on backorder with short expected delivery time.
On the speaker itself (a friend owns a pair), i know that one, and for it's price down here (130-150€ for a single one) it's a great speaker. But if they charge 500$ for it like some say it's way to expensive. It's not a bad speaker, just a bit hard and not so detailed sounding subjectivly. But much better than all i know at it's EU pricepoint. The graphs confirm more or less that subjective id I had of them.
juliangst
Germany
I‘m looking for something decent to replace a Marshall Bluetooth speaker with and this might be it for 130€.
Other speakers I considered are Adam T7v and Kali LP6v2 but I can’t tell if they’re worth the 80€ premium over these M-Audio speakers
Adi777
What source would you connect for these speakers, or Kali?
juliangst
Germany
Raspberry Pi with DAC board running moode and Camilla DSP.
This allows for some speaker corrections and also mixing to mono because I only need one speaker
pavuol
EU next to warzone :.(
I guess it was previous "D2" gen. that had round tweeter waveguides and sites/reviewers sometimes threw random pics and caused confusion (?)..
My local price comparison site shows D2 was sold in years 2011-2017, this D3 2017-till now (so both ~6years), so maybe some D4 iteration slowly on the way, maybe also not due to market expectations..
Anyway this is Class A/B amplified, out of curiosity someone could measure power consumption and compare it (volume matched) with some class D monitors, like LSR308, T8V or so..
