That, in my opinion (just my opinion) is a myth, created by their marketing info, no scientific base if you look at their own published specs and bench test results, but I do appreciate that Marantz fans are firmly entrenched in their belief because they trust what they perceived and probably don't believe human bias/Placebo has much effect on them. Even if they read studies, such as Harman's that showed such bias are very effective/impactful. Not trying spoil your fun, and I highlighted "opinion", I would have love to own a Cinema 30, to me, it is the most impressive AVR even made as it has the best mix of features, quality parts, aesthetic, circuit board layout, physical dimensions and weight, as well as specs and measurements (based on Marantz's own, that I trust, based on their reputation and past history).
By the way, I just AB compared my new Denon vs my Marantz preamp/power amp in two channel, I actually thought the Denon had the "warm" sound, tried it in both Dirac and pure direct, same results. Not tightly controlled, totally sighted, though in this case, the sighted part should bias me to hear the warmer sound from the Marantz pair, very weird, lol... The human mind is really interesting, can be imaginative, and perception could be highly variable depending on many factor.
Fully agreed, as I believe in known science, but I don't know why I would have such bias!! a) I did not feel that way with any of my previous Denon AVRs, b) the forum, magazine reviews talks etc., have over the years, jammed my head with the warm Marantz sound possibility/reality already. So, I guess may be my bias is due to low expectation, that such a below 20 lb soak and wet AVR should sound "thin"? All my other Denon avrs that I actuallly used for more than 1 year are the midrange to upper midrange models. I have never owned any Modern Marantz AVRs, only AVPs, preamp, and power amp, except I did install a system based on the SR7009. Yeah, the human bias thing is incredible, you can hear and see all kings of things are not what they are when you have the bias removed, one way or another.You were biased on proving that Denon is as warm as Marantz, so you heard what you wanted ;-)
Oh no, if it was then I wouldn't be surprised at all, I guess... I have been comparing my other gear with the little 19 lbs AVR-X1800H, used strictly for 2 channel stereo with just one small subwoofer. It has the dreaded PCM51020A DAC IC that has only 93 dB SINAD spec., though AVRs using that IC did manage up to mid 90's SINAD on Amir's test bench, indicating that Denon/Marantz has done excellent work in their implementation scheme of such an entry level TI DAC chip.Were you testing it against the 6800? Would make sense since the DAC is the same
Contact Dirac and ask about their money back policyNow I am tempted to try DIRAC but if I spend 799$ and afterwards I realize that I like Audyssey more... I will feel really stupid. I had an arcam some years ago and I liked Dirac, with some reserves: the soundstage was narrowed and in Music it was too punchy and defined for my taste (I like some dispersion in music)
I am sure @Flak can give you the official answer. My guess is, probably not possible but I hope I am wrong and if their marketing is smart they should offer such free trial. It is definitely possible if you don't mind trying the PC standalone version, that does have the trial option. You would to use your PC and will therefore be limited to stereo, and whatever multichannel configuration that version can do.Are you serious? can I try 14 days and get a refund if I am not satisfied?
Well, I would need to try it on my receiver with my speakersI am sure @Flak can give you the official answer. My guess is, probably not possible but I hope I am wrong and if their marketing is smart they should offer such free trial. It is definitely possible if you don't mind trying the PC standalone version, that does have the trial option. You would to use your PC and will therefore be limited to stereo, and whatever multichannel configuration that version can do.
I know, but if you have a laptop, it should be easy to do, especially if the laptop has HDMI output.Well, I would need to try it on my receiver with my speakers
Yes use HDMI for 5.1, 7.1 etc. You don't have to use pure direct mode, just turn Audyssey off will do.OK so with a laptop I could use the Desktop version and send it to my receiver... in Pure Direct mode I guess? Otherwise the AVR would be doing its own things on sound
According to the official EULA, refund is only if you haven't used the license (unless they've changed this recently)!Are you serious? can I try 14 days and get a refund if I am not satisfied?
You are dependent on a forum member who works for Dirac to get you that money back.
They denied your request?That's what I had in mind (no refund after trying), hence my surprise
You don't ask in this forum or any other forumAccording to the official EULA, refund is only if you haven't used the license (unless they've changed this recently)!
It depends on how busy he is, sometimesyou get same day response, other times it could take 1 to a few days.I wrote some hours ago, no reply yet
They have none and have the worst customer service ever!Contact Dirac and ask about their money back policy
If you think about it, paying $799 for a software is crazy. It is a just a software and moreover, it is a software that you will use ONE day (or few days until you get what you want). There are softwares that you use everyday and are much more economic
