Now with the easy parts being done correctly, maybe
(in the case or AVR's, etc) we can begin to concentrate on better DRC, start looking into things like, are the codec's
like Dolby THC, DTS HT and all the rest performing to spec? I'm not an engineer but I've wondered do these things
perform as they're supposed to going from one builder to another. Is there a way to measure these things and see what's
going on there? Is there a possibility that Denons implementation of the Atmos decodeing in their AVR's different than
Arcams or Monoprice, or ??? Is there a way to check these things? I've never heard anyone even begin to discuss it?
I don't understand these things so maybe there's nothing to be concerned about ???
Just a bit of a rant maybe?
Although anything is possible, decoding is generally policed by Dolby, DTS etc. As I understand, they would certify the implementation so that the manufacturer can use the relevant logo and technology. It's a fail or pass test so theoretically there should be no inferior or better implementation. Obviously the rest of the AVR design and implementation will impact the decoded sound in some shape or form (separation, dynamic range, noise etc.), but I don't think that is what Dolby or DTS are particularly picky about as there are lots of lower end AVRs bearing the certification. They certify the integrity of the decoded signal, before further processing.
THX has different levels of certification for audio components where Dominus would be the highest and THX the lowest level, but it seems that has lost its appeal in the world of AVRs/AVPs. Not really sure what are the requirements of different levels for AVRs though.
AVR's processing units are another area that could be looked into. It seems that there is plenty of power in the current line-up with lots of manufacturers e.g. being able to implement Dirac Art on their current models that requires a slightly higher processing capabilities. There is still a question if the room correction could benefit from higher processing rate than 48khz, which might require beefier processing units. As I understand, most say 48khz is good enough, especially for movie soundtracks.
Dynamic range is a matter of overall design. Higher end AV-10 and AVM-90 AVPs are at around 113dB. My other AVR, Denon 6700H is at around 108dB, and equal to Trinnov, which is a bit higher than some other popular ones like Onkyo RZ 50 at 105dB. I had no complaints as far as 108dB, but yes, higher is generally better.
I think that we are currently pretty good on the state of hardware, except for pricing which is insane. But so it is in other areas of life, unfortunately.
