- Joined
- Feb 27, 2018
- Messages
- 977
- Likes
- 1,078
I did a few casual tests against the K1 and sadly, its measured performance is worse than SMSL iDEA. Will need to repeat the tests again to be sure but thought I share that with you.
Does the performance degrade terribly at a 0 dBFS level versus something less as some have claimed is a consistent problem with PCM5102-based devices?
Also, what load impedance did you use?
I ask because, given that it the K1 has no volume control, I use the volume slider in Foobar with my 36Ω RE400 IEMs, and it shows that I normally run ~ -20 dB attenuation on LOUDLY mastered pop/rock and rarely louder than ~ -14 dB on older classical material that's mastered "classically."
