VMV D1se2 Stereo DAC Review
Rate this DAC:
    Votes: 13 6.3%
    Votes: 11 5.3%
    Votes: 60 29.1%
    Votes: 122 59.2%
This is a review and detailed measurements of the SMSL D1se2 stereo balanced DAC. It was sent to me by the company and costs US $720.
I like the smooth font used and the highly responsive rotary control. VMV is the high-end brand of SMSL and it shows in inclusion of a nice metal remote:
I wish SMSL would add trigger in/out and color code the RCA connectors. Otherwise, the unit is easy to use and configure.
VMV D1se2 Measurements
Let's start with our balanced output dashboard with volume set to 0 dB (goes to +2 dB):
This is excellent performance and easily lands the D1se in our top 20 best DACs measured as far as SINAD (noise+distortion):
RCA performance as usual is a bit worse but still beyond transparent:
Here is the SINAD vs position of volume control:
Noise performance is a bit worse with RCA (typical) and hence the slightly lower SINAD:
IMD performance is superb:
There is a hint of low frequency jitter which is utterly inaudible:
Multitone performance is exceptional:
Linearity is perfect:
We have the usual set of filters:
SMSL VMV D1Se balanced stereo DAC XLR USB Frequency Response Measurements.png
Suggest avoiding "off" and going with Fast Linear:
SMSL VMV D1Se balanced stereo DAC XLR USB THD+N vs Frequency Measurements.png
I expect state of the art performance in DACs from SMSL and hence VMV and that is what we get in D1se. Competition is starting to advance feature set with fancy display and such. Hope SMSL follows the same trend and give us something to look at while playing music! :)
I am happy to recommend the VMV D1se2 stereo DAC.
asrUser
What's inside, ESS or AKM?
Ziroz
Look at that CNC'ed aluminum remote, truly glorious! At this price I would imagine buyers wanting a large and hefty CNC'ed chassis as well, so maybe throw in some extra metal next time.
Talisman
Milano Italy
@amirm thanks for the review, I understand that this is a nuisance for you, but it would be nice to test the bluetooth of the dacs, especially regarding Ldac, there is still a black hole in the measurements of these protocols (excluding some of your measurements, but few). I wonder if they are all implemented the same way and what performance they offer. It would be nice to have them
Talisman
Milano Italy
with SOTA DAC come out more and more, I hope manufacturer shift their focus on reducing the price of next products. Keep throwing $700 DAC at us doesn't make any sudden increase of wallet thickness :(
you can find dacs with sota performance and balanced outputs even under 200 euros by now. see smsl C200
VintageFlanker
Paris
Thanks for the review, @amirm
I honestly don't understand the very existence of this product, tho. Do Topping and S.M.S.L plan for different offerings for every 50€/$ slices ?... Their own market and ranges are just overcrowded.
AFAIC, I measure every BT codecs available when I can. I made quite a few THD+N measurements with LDAC (both Analog and Digital domain) and it's often on par with what you get from regular digital inputs, for sub-110dB SINAD DACs. And about 112dB+ SINAD in digital measurements (still 1kHz sine, WAV file, 24b/44.1kHz).
I happen to have a CD Player/DAP, planned for review someday, which gives me about the same results with USB-in and LDAC (≈104dB in that case). Haven't seen a "broken" implementation so far. Still have to measure aptX HD, tho.
Talisman
Milano Italy
and it's often on par with what you get from regular digital inputs for sub-110dB SINAD DACs. And about 112dB+ SINAD in digital measurements (still 1kHz sine, 24b/44.1kHz).
So basically transparent? This is good news (and I've never recognized ldac from optical or coaxial signal)
I think they are all the same: https://www.audiosciencereview.com/...c3-review-bluetooth-receiver-bt-codecs.23740/
But sure, I will do a spot check here and there. In general, if you have LDAC, that is the codec to use. All the others sound pretty lousy to me with the worst being AAC. If you don't have LDAC, then SBC is the second best.
Adding on, it is fair bit of work testing Bluetooth as my analyzer doesn't have that option. So I have to mess around using my phone. Audio Precision Bluetooth option costs $6,000 or so! I don't know how they justify that cost but I am not going to pay it. :)
JamesYeomans
To be clear though, you use an Android phone. I believe AAC is more optimised for iOS devices and sounds good to me via bluetooth
VintageFlanker
Paris
Sure, playing some test files with UAPP set as bitperfect, selecting the codec in Android settings, and measures what comes out either analog or digital outputs of DUTs works fine for me. ;)
Not sure the need for spending 6k on this. o_O
TheWalkman
Great product, technically, but why drop $720 on a DAC? Probably the same reason I prefer to drink $15 bottles of wine instead of those selling for $150— my ears and taste palate (and ego) are no longer that discriminating
respice finem
Maybe they're testing the waters of the "audiophile" swamp market :cool:
