Measurements of Singxer SA-1 Headphone Amp(Preview)
AdamG
Moderator
Reality
Celty
deafenears
H-z is to change the output impedance of the headphone output from 1.4 to 10 I think it is. I don't see why you would want to do that unless it was to mess with the sound or to use 600 ohm headphones or something.
On Passion for Sound's YouTube channel, it shows a bit of bass boost with the Focal Utopia with H-z:
The Utopia has an impedance of 80Ω.
Might also help with some IEMs such as the ThieAudio Monarch per Crinacle's testing (site seems to be unresponsive to me at the moment so unable to link to the graph, but when it's up - https://crinacle.com/2020/08/26/thieaudio-monarch-and-clairvoyance-review-twin-wins/).
T
tom.chen
In the high resistance mode, the control power of the diaphragm will decrease, so the low frequency will be enhanced.
Veri
Orrrr the impedance mismatch causes a slight elevation of "low end energy"? :D
Extreme_Boky
Hi Tom,
I hope you are still lurking....
I posted in the other thread, so I'll try here as well:
Can you please tell me which serial numbers are going to ensure that, If I buy an SA-1, I will get a unit with the additional power rails' decoupling SMD caps (placed around those blue coloured 10ohm SMD resistors)?
I also see 8 protruding solid core wires, coming from underneath the PCB... are there high power resistors mounted underneath.... maybe in contact with the bottom plate, to dissipate the heat
Many thanks for your reply!!!
