- Joined
- Oct 25, 2019
- Messages
- 11,112
- Likes
- 14,777
Learn something everyday!It does, I use it regularly in low gain mode
Let us know how you like it!Now, $22 in Aliexpress...
I bought one...
The pro? Treasure!Now, $22 in Aliexpress...
I bought one...
I bought one...
That's the dongle's digital hardware volume, controlled by UAC2 commands.Question chaps, might sound too naive. In Windows does the volume indicate the hardware volume or the direct sound volume that is being sent through the DAC? I can't go past 14~16 out of 100 on low gain even with Sennheiser HD560S
Did you mean Wasapi ? I suppose then I have to be very careful with using the volume slider within the foobar2000 applicationThat's the dongle's digital hardware volume, controlled by UAC2 commands.
If you're unsure, just try playing foobar in Wasabi mode. If the volume slider still works, it's hardware.
Foobar's own volume slider is always software. Windows' slider is software with regular DACs and automatically switches to hardware with compatible DACsDid you mean Wasapi ? I suppose then I have to be very careful with using the volume slider within the foobar2000 application
Thanks, I had no idea and checked it with my D10s. Windows slider is synchronized with Topping driver volume output control. Tempted to use keyboard media volume binds instead of L30 volume pot from now on because I'm too lazy to reach it with my hand sometimes.automatically switches to hardware with compatible DACs
Are you sure you found the Meizu HiFi Pro and not the Meizu Master Hifi? Because that one's just a rebranded, regular Meizu HiFi from what I know.So I just found the HFi Pro on Amazon for 22,99- here in Germany.
Digital hardware volume will reduce your bit depth, yesThanks, I had no idea and checked it with my D10s. Windows slider is synchronized with Topping driver volume output control. Tempted to use keyboard media volume binds instead of L30 volume pot from now on because I'm too lazy to reach it with my hand sometimes.
Do I lose some "bitperfection" with this method? I can't tell the difference.
That's why I have to be a little more careful not blowing up my eardrumsFoobar's own volume slider is always software. Windows' slider is software with regular DACs and automatically switches to hardware with compatible DACs
To avoid clicks over 48khz? So it is not possible to take advantage of dsd and high resolution right? Limited to 48khz
Not sure which post you are replying to . This device can play higher resolution PCM above 48 khz no problem. Never tried DSD.
I recently got the meizu master hifi, I use it on the pc. Which sampling rate do you recommend? 32bit 384? 24/96? Putting the maximum available (32/384) are there problems with audio interruptions?Playing 44.1KHz on the regular Meizu HiFi using UAPP will result in stutter. 96/192/DSD works fine from what I remember.
The Meizu HiFi Pro doesn't have this issue at all.
Furthermore, when playing 44.1KHz content on the regular Meizu HiFi with foobar wasapi output, no stutter occurs.
