https://www.audiophonics.fr/en/powe...ifier-class-d-ncore-1x500w-4-ohm-p-14319.html
Seems to be very cheap. XLR + RCA and 12V trigger.
and hopefuly soon Purifi ...Thanks to @Audiophonics for keep offering entry level amps with almost all the NCore line.
NC500MP has built in power supply and buffer. NC500OEM does not, and manufacturers have to add them separately.Hi am I missing something Is an nc500mp inferior to nc500? Is this Hypex? I am looking for some class d amplifier is this a good thing?
I wish they used a more fitting chassis. All this empty space this deep for nothing... Good price though.https://www.audiophonics.fr/en/powe...ifier-class-d-ncore-1x500w-4-ohm-p-14319.html
is there 1/2 the power with stereo at the same price? "
It is.Is that just the mono version of this one?
https://www.audiophonics.fr/en/powe...s-d-amplifier-2x500w-4-ohm-ncore-p-13344.html
Probably someone ordered a unit and they got extra modules to make mono blocks ;-)It is.
Note taken.when we will release the NC500 OEM one
I think there are still wrong mentions of NC252MP in the item description.We just updated MPA-S252NC to MPA-S250NC, because it was a mistake.
I like them. Standard size and looks and feels sturdy.I had to spend quite a bit more just to get units that would fit on my shelf. The @Audiophonics case is hard to understand.
