Periodic Audio Rhodium DAC Review
This is a review and detailed measurements of the Periodic Audio Rhodium DAC and headphone amplifier/adapter. It was kindly purchased new by a member and drop shipped to me. It costs US $99 but company has it on sale for US $49.
The Rhodium looks like any other USB-C phone dongle:
It was plug and play on my Windows 10 PC and that is how I tested it.
Rhodium DAC Measurements
As usual, I test these dongles as DACs (with high impedance load) so that we can assess its performance without the headphone amplifier portion (even though it is still in the loop):
Ah, this is not very good. Third-harmonic is quite high at nearly -81 dB which dominates the SINAD to the same tune. Output voltage is only 1 volt which means it will not have much power to drive high impedance headphones either.
Jitter test showed nice, flat noise floor but some data dependent jitter (due to 250 Hz square wave in j-test signal):
Most important test here is amount of power so let's start with 300 ohm load:
As suspected, there is not much power here:
Switching to 32 ohm load we get:
Company spec is much higher (around 35 milliwatts). Maybe that is one channel with much more allowance for distortion.
Listening Tests
I tested the Rhodium DAC using my Sennheiser HD-650. On tracks with full amplitude, there was enough volume to enjoy so dynamic power should be higher than shown. But on any track with less than max digital levels, I didn't feel there was enough volume there.
I met the company at an audio show and was impressed with their objective approach to headphone design and measurements in general. I am therefore disappointed to see such a low performing dongle sold at rather premium prices. I hope they can upgrade the platform to something better.
As is, I can't recommend the Rhodium DAC. Hopefully I don't loose another professional colleague in the industry over this review. :(
pozz
Слава Україні
Editor
I had a good impression of the company as well. Results match the <0.007% THD spec.
Would you mind measuring max SNR as well, if you still have it?
pozz
Слава Україні
Editor
Thanks Amir. Could be truncating to 16bit? Regardless, the output power is very low.
jasonhanjk
3rd harmonic is higher. If reduce the media player volume to 97% would that improve?
Weird, it's advertised as having 31 mW at 32 ohms. Seems a little off that it's only doing 7 at 33.
The usual practice is to test one channel. If so, then it is 14 mw compared to 31. And then if you allow more distortion than I did on that hockey stick, maybe one gets close.
So many people push this spec to the max that vendors almost have no choice but to play by the same rule.
PeteL
Rocking the lab coats never hurts in projecting this vibe
cursive
Do you always use the same percent of distortion as a cutoff? I didn't see it listed in the review, but is it .001%? Or is there a way to see the percentage from the graph that I'm not aware of.
pavuol
EU next to warzone :.(
Never heard of this company but looking at "about us" section of their website they seem like likable guys..
"We do not court sports-stars or media-darlings to validate your emotional insecurities.
We just care about music. And that it should move you. "
Hopefully measurements will reach the level of their humor in their future products ;) I mean, proper chemical mixture..
AudioSceptic
Northampton, UK
Listening Tests
Amir, I know you like to use the DX3 Pro as a "standard" for DAC-amps, but for these tiny adapters, wouldn't the Apple USB-C adapter be a better example to show in your graphs, as it competes in the same market, unlike the Topping?
PeteL
Looks like Realtek based USB->DAC-HPA combo, a VERY convenient chip, and crazy cheap($1+a few passive parts!) but really junk audio performance. Tonnes of similar "DAC"s on the Taobao today for a hamburger cost.
doubt it. Do you have the specs or model number of this IC? The Periodic Audio Dac supports 384 kHz. I don't know any 1$ parts that do this.
IVX
South of China, SHZ area, - Слава Україні
PeteL here you are ;) I may mix up the price yet, probably ALC4050 is the most expensive Realtek USB-audio chip nad its cost $1,5(the PCBA from my pics 15RMB on taobao, it is $2.3) but they have previous chips like ALC4050, probably even worse but $1 indeed.
  • ALC4050_DataSheet_1.2.pdf
