Revel F228Be Review (Speaker)
MacCali
How does the M105 compare to F226Be? I am debating on upgrading to F208 or F226Be from M105.
There’s a measurement and score on the F series that’s very good almost outstanding I believe.
Absolute
Yeah, in fact that Revel doesn't have any distortion problem neither a peak in the spinorama
That being said, in other speakers where i found a distortion peak sometimes correlate more.. for example, the reviewer have wrote this
'' high-Q resonances in the cones are visible at 3-6kHz '' and then the distortion casually have a rise right there...
It seems like there's corresponding anomalies in the spin, but likely too little to have any impact on listening tests. Might show up with pink noise or test tones.
ahofer
New York City
Picking up a pair of these used. Should be an interesting comparison to my Harbeths. Unfortunately, will be in a different house, and I”m not sure I’m up for the transportation for direct comparison.
MacCali
Think it shouldn’t matter right? Isn’t this the speaker which pairs well with any room.
I know the harbeth will sound different but the revel should be a constant or consistent. I’m sure someone will chime in :)
ahofer
New York City
MacCali
Well…here’s the room. Should challenge that concept pretty strenuously.
Thread 'Room challenge and DSP'
https://audiosciencereview.com/forum/index.php?threads/room-challenge-and-dsp.9178/
I mean no matter what, didn’t take a close look. As long as you make everything equal distance you can probably make it work. I know onrush side has no wall, so you need to put acoustic treatment for the wall with reflection.
It won’t fix everything but help a bit. All that matters is making the reflections similar.
I will take a closer look, but I am far from an audio expert. Just chiming in with what I understand and that may be useless or there’s no way to set it the way I’m saying
ahofer
New York City
ahofer
New York City
I have to say, as I live with both my Harbeth SHL5+(AE) and these Revels, it’s the orchestral music and seating flexibility that reveal the superiority of the Revels. Listening to the Rachmaninov 2nd now at volume, well off center, and it’s great.
It’s a mistake to audition speakers with sparsely orchestrated music, or at least with only that. Throw an orchestra or some electronic music at it.
MacCali
Think it’s the same with most well behaved speakers. If my memory serves me correct that’s the one Erin tested
Nkam
Preference Rating
SCORE: 6.2
SCORE w/ sub: 7.6
Sensitivity: 89.3dB (300Hz-3kHz ; spec: 90dB)
Frequency response: +/- 3.2dB 80Hz-20kHz
since the tweeter is so high and usual listening positions according to stereophile are around 32-39” while usually somewhere around 34” wouldn’t that automatically mean the on axis vertical measurements shouldnt really be taken into account but the -10deg and -20deg measurements or in between?
can someone educate me on this please?
thanks
amper42
thanks
The Be Tweeter in the Revel F228Be and F328Be works fine in various seating positions. I have not experienced any issues with my F328Be tweeter regardless of the seating position. However, with the BMR Monitor or BMR Tower with RAAL 64-10 tweeter, being at ear level with the tweeter does make a difference. Different tweeter designs will determine how important being at ear level really is.
