Revel F328Be Speaker Review
Xyrium
Unbelievable! 100 speaker reviews in less than a year, despite throwing out lots of other reviews as well! This is heroic (bowing low).
Did you count the two KH80 remeasures to the 100? ;)
You've earned a vacation, but this is not a good idea right now. Maybe measure the KH310 in the meanwhile?:)
Exactly! Throw in the remeasures of the Kali with the busted woofer, and a few other repeat model measurements...
That said, wow, these really do crush the spectrum very cleanly with record setting directivity, just around an xover point for a few subs to round out the bottom. It seems as if the multi woofer design was chosen to keep distortion low, not create earth pounding bass. I applaud the effort entirely.
Now, this is one of those reviews where I'd love to see IMD being measured. The THD was so low, that it would be very interesting to see IMD on the cleanest, and lowest performing products in the stable. I know, it's always something....and IMD would be time consuming ;)
Great work Amir, rest up that back of yours!
wwenze
So the lesson here is at 200Hz or lower you can spam as many woofers as you like and you won't have directivity issues. This correlates with experience with 2.1 systems.
I am curious about the bass performance of this unit. Amirm says this speaker has phenomenal bass yet eyeballing the measurements, it looks like the -3dB point is 60Hz when being generous.
Possibly because with anechoic measurement the "wall of sound" from the 3 woofers just tilts away as the speaker is rotated, but in a room their sound pressure has nowhere to escape to.
HooStat
Calabasas, CA
Have to say, the measurements look better than the Olive score says they are, at least to my eye. Also, taking into account that distortion and near perfect 70 degree beam width, this speaker is in the conversation for best measured to date. 8341 is definitely smoother, and has better vertical dispersion, but it also lacks in other ways, like output, and a narrower beam width(for those who prefer wider).
I agree. Something seems off with the score. Particularly the difference for the sub being +2.2. It just doesn't seem possible that the improvement with the sub is bigger than for the Genelec 8341.
MZKM
Land O’ Lakes, FL
The Genelec is still more tonally balanced, even though it needs to be viewed under a microscope. And while Amir mentions the issues with measured bass performance, the Genelec still likely extends deeper. The Revel of course will get louder and have less distortion.
Below is a comparison with a really squished x-axis of the two.
richard12511
Yeah, I went back and looked at the 8341 review, and it is a bit better. Odd that the Genelec extends deeper, I assume some of that is just dsp? The Revel also has a wider beamwidth, which some might prefer.
richard12511
Going off this, is there a reason more manufacturers don't stack woofers above the tweeter to match the woofers below? I know JTR does it with their biggest towers, but for the most part it seems that designers just put woofers below the tweeter. Is it just for aesthetics? Or are there dispersion consequences for doing that?
Helicopter
Michigan
What a pleasant surprise. Thanks again, and congratulations on 100 reviews.
This speaker exceeded my high expectations. I would probably get these over Salon 2 because they are a new design, they look great, and they are priced more competitively.
PierreV
I am guessing mechanical/structural constraints play a role as well. After all, the woofers are heavier and typically need a bigger chamber.
restorer-john
Many of the cost no object reference designs from the past had woofers both above and below the mid/tweeters. They obviously get pretty tall however.
Think Duntech Sovereign
Jamo Oriel
Dynaudio Consequence
Kaiju
Congrats @amirm for the 100th speaker review. Please keep them coming specially $4000+ speakers :D
