nathan
- Joined
- May 24, 2020
- Messages
- 368
- Likes
- 255
I would generate a room EQ based off the measured response in your system and try that out. Chances are good that will make the most impact in the frequency range below the room transition frequency ( hence the 500 hz generic recommendation) but there Is no law against trying a different approach, and Eq-ing a wider range of frequencies, especially is they are behind a screen, etc.I have these speakers as LCR in my home theatre. I always hear that I shouldn't EQ speaker above 500Hz. However, can I generate EQ based off of the spinorama for these speakers? If so... Is there any analysis done on this data to create a PEQ?
tldr, rather than EQ their anechoic response why not use EQ to counteract the ways they interact with the room (ie the Toole approach).
