Review and Measurements of Audio-gd R2R11 DAC & Amp
This is a review and detailed measurements of Audio-gd R2R11 DAC and headphone amplifier. It is on kind loan from a forum member. It retails for USD $350 plus shipping. From what I can tell, you have to send money via paypal and then the product will be shipped to you as there is no formal online store. Customers in Europe though can purchase it from distributors there. The only price I see is 369,00 € tax included.
I have had many requests to measure this unit and I am very happy to finally get one to review. The unit being an unconventional, discrete "R2R resistor ladder," as opposed to vast majority of DACs we test which are built on integrated DAC ICs (chips). This brings an appeal to many people, considering such DACs as more natural sounding. This has made this DAC and the ones like it from Schiit, etc. very popular.
This is the lower-end of DAC products from Audio-gd and as a result dispenses with displays and such:
Ah, what a joy it is to have simple switches that control functions as opposed to convoluted button presses and cryptic display in their higher-end units.
There is an integrated AC power supply, eliminating the wall power dongle.
Sadly there is no balanced output which I like to see in this price range but I appreciate that this doubles the circuits for the R2R ladder DAC.
I am sure you all are as anxious to see the measurements as I was when I put it on the bench last night so let's get into that.
Measurements
The last two Audio-gd DACs I have tested, unfortunately performed poorly. Would the R2R11 be any different? Here is our dashboard view with RCA outputs:
Sadly the answer is no. We have really poor performance yet again. Not only do we have our usual high harmonic distortions but now, have lots of other interference and glitches from mains and other sources. SINAD as a result suffers putting the unit squarely in a class by itself beside other Audio-gd products:
Levels in fixed output mode per above were a bit hot at 2.4 volts. Putting the unit in variable mode and reducing the levels though made no noticeable difference.
When I was running my dashboard, I noticed every once in a while the waveform would get distorted and THD would shoot up. I checked and all of my Windows/ASIO buffers were set to large values to avoid buffer underruns but the problem remained. Wanted to confirm it, I ran a continuous measurement, watching THD+N as time went by and got this:
As you see, like clockwork, every 25 seconds or so we get a spike in distortion, confirming the problem I saw. There is a clear implementation error here.
To avoid having this impact the measurements, from here on I tested with S/PDIF input which did NOT exhibit this problem.
Audio-gd does not provide any specifications other than signal to noise ratio of 100 so let's see how she does in that department:
So about 10 dB shortfall which is pretty significant although similar to performance of Schiit Modi Multibit.
Linearity tests become super important when we are talking about custom/R2R DACs. Ideally, we should see an output that varies in voltage in direct and precise steps to digital inputs. Here is what Audio-gd does in contrast:
This is the worse measurements of any DAC. The R2R11 loses linearity very early on (-40 dB) and by just -63 dB loses my threshold of pain of 0.5 dB. By the time you get anywhere close to CD's 96 dB dynamic range the Audio-gd R2R11 is on the next planet in another solar system.
Any more bad stories? Sure, let's look at jitter and noise:
The J-test source signal toggles a single bit in 24 bit words to the tune of 250 Hz. This creates a square wave at that frequency which should NOT appear in the output as its level is well below noise. Not here. That square wave is causing pretty major disturbance causing distortion spikes as high as -55 dB!
Embedded in there is also another train of jitter and spurious responses at lower levels which thankfully are inaudible but show dual mechanisms for corruption of audio samples. Lots of power supply noise generates the congested cluster on the left and then around our main tone at 12 kHz.
People unfamiliar with signal processing quip that "single tones are not music." Well, they are because your music can completely represented by the principle tones but ignoring that, we can run a test with 32 tones and see the response there:
Ideal response would be those 32 tones with bottoms way low and nothing in between troughs. Of course we don't see anything like that. Instead, we have large amount of distortion products raise the effect noise floor by some 50 dB. Any hope of hearing detail in your music will go out the window and replaced not just by random noise but correlated and uncorrelated distortion products. But we knew that from our earlier tests, did we not?
Even in a test like white noise to see filter response we see odd behavior:
For proper reconstruction of audio samples, we must filter everything above half the sample rate which would be 20.05 kHz. In the Audio-gd R2R11 there does not appear to much of any filtering. The math therefore predicts aliasing.
For completeness, here is the square wave response:
What do you think intermodulation distortion versus level looks like?
Notice the jagged distortion as levels change showing discontinuity errors in the DAC implementation.
Now let's look at the headphone output performance. Output impedance is stated at 2 ohms. I get almost 9 ohms instead!
I am scratching my head how they could mis-specify this simple metric. I tested it twice and each time, adding a load to the headphone output substantially lowers its value indicating high source impedance. Now, this is not end of the world but be careful if you use headphones with low but varying output impedance as this could change their frequency response (for good or better subjectively).
Next is power versus distortion at 300 ohm, simulating loads like Sennheiser HD-650 headphones:
Audio-gd R2R11 DAC and Headphone Amp THD vs Power at 300 ohm Measurements.png
Out previous measurements of noise and distortion come to haunt us in erratic, high distortion and noise response in both low and high gains. Power is very good at 150 milliwatts although no better than the Topping DX3 Pro shown for reference.
The bad news continues with 33 ohm load:
Audio-gd R2R11 DAC and Headphone Amp THD vs Power at 33 ohm Measurements.png
The issues we saw in intermodulation test of course show up in these loads just the same as we vary the input level to plot the power vs distortion.
Listening Tests
I started listening with my Sennheiser HD-650 headphones. My music tracks for headphone testing are designed to test the power limits of the headphone amplifiers and here, the Audio-gd R2R11 did fine. It produced thunderous bass, easily able to push the Sennheiser to produce them well. This explains why many people like this product. If you are coming from an anemic headphone amp or no amp at all, you will be most impressed with this unit.
Similar outcome was waiting for me with Hifiman He-400i. So in casual, isolated listening not much pops out despite the excessive distortions and errors in the output of the Audio-gd R2R11.
I then set up an AB test between Topping DX3 Pro and Audio-gd R2R11. I then matched levels, ganged the two DACs in Roon to play in sync and started to listen. With my busy headphone test tracks performance was actually pretty similar. Importantly, there was NO coloration in response of Audio-gd. I read countless posts online about how these ladder DACs sound different, more pleasing, etc. I could detect none of that across a bunch of tracks. Anyone who thinks otherwise, needs to perform such an AB test to realize differently.
I next ran a set of tests with more isolated instruments. Here there were some subtle differences to my ears. High frequency transients were, forgive my use of audiophile term, muddier in Audio-gd blending more into the rest of the music. Note decays suffered some just the same.
I wanted to run more listening tests this morning but we lost our power and I am typing this under generator power. And at any rate, will be going on a trip later today so need to pack and such.
With now three Audio-gd products tested under our belt, the conclusions are abundantly clear: the company chases audiophile imaginations and lay intuition, producing products that lose the word "fidelity" in high-fidelity. Nowhere this is more clear than in this DAC where every test shows massive deviation from ideal or what the competition delivers.
Please don't say these are musical distortions. There is nothing musical about erratic performance of a DAC and amplifier. Your music was not produced with these devices. Any deviation here is distorting that creation with no intention of musicality in mind. It is like saying the dirtier the dishes in a restaurant, the better the dish would taste. I don't think so.
I took a look inside to make sure the jumpers were as shipped (they were) and you see tons and tons of circuitry as you do in other Audio-gd products. Getting all that to work and manufacture, is not an easy task. That talent and resource though is applied in totally wrong direction. Yes, differentiation is good but not in producing such poorly executed end product. We want transparency in our product, not a random mixture of distortions, all conspiring to reduce fidelity. I hope Audio-gd changes direction and starts to produce well-engineered products rather than a set of buzzwords in spec sheets.
Needless to say, my advice remains to avoid purchasing these Audio-gd products. They are antithesis to what it means to be an "audiophile." That word better have some meaning left it in.
If you like this review, or even if you don't but wish for me to ride first class in my upcoming holiday flight, please consider donating using:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
yue
btw it is pretty hard to believe a DAC with SINAD=65 sounds as transparent as DAC with SINAD=106. I once believed -65db harmonics should be pretty audible...
Distortion of these types is subject to masking effect and hence content dependent. We are not talking about frequency response errors that would be audible for every piece of content.
Also keep in mind that my ears are aging so you mileage may vary.
Krunok
Zg, Cro
And kudos to your patience to listen to this crappy device and providing as with your listening impressions!
garbulky
Once again a "trash" dac that sounds about the same as a well measuring one in a DBT.
Having said that, yikes these distortion measurements are now in the audible territory! As well as poorly implemented glitching and weird 25 second THD issues. Not a good showing. Imo there's no real excuse for releasing it with distortion measurements in the audible territory.
Amir did you take any XLR measurements?
confucius_zero
That's some sick burn right there :O
graz_lag
Le Mans, France
After the March Audio's sea storm @amirm has triggered a super-nice and pro review ... for a machine that is a total disaster, unfortunately ... o_O
I would be scared at the idea of being in the position of the European importers of this Audio-gd brand ... and more at the idea of being one of the hundreds European fellows who bought this erratic machine ... o_O
elira
I'm surprised how people like something that has this kind of measurements. I guess we're measuring the wrong thing, otherwise the R2R-11 would sound terrible and nobody would buy it.
rmo
Measurements
Listening Tests
WOW, AUdio-GD is a DOG with FLEAS.
Not really. We are blessed with hearing system that is used to ignoring a lot (notice how much other animals are more sensitive than us). We are doubly lucky that audiophiles as a group, are not critical listeners. These factors combine explains why there is no mass revolt against products like this.
People keep talking about how great their hearing system is. This review is proof positive that their hearing is horrid. They can't even hear artifacts in clearly broken products.
Headphonaholic
I've nearly bought an Audio-GD product due to all of the hype they tend to get in various audiophile circles... I'm really glad I didn't. If you look past the bad english and terrible site design, their site is very convincing as well. They show the internals that look impressive! There are a few measurements and they explain things... to the uninitiated, it is all very convincing and impressive. Not sure if their intention is to mislead but I can see how it works.
VintageFlanker
Paris
I have to admit I owned and liked the R2R-11. Why? because of its distortion, maybe. I found this to have a very smooth and tubish sound. Nothing close to neutral and linear, but likeable all the same.
C'est du foutage de gueule ! That's total garbage ! o_O
Still... Audio-GD remains VERY popular here in France.
