Review and Measurements of Audio-GD R8
WolfX-700
China
In past measurements we have confirmed that even discrete R2R can perform very well.
However, many devices using the same type of technology perform poorly, which is why I mentioned in my previous measurements that I instinctively hate discrete R2R.
Today we have ushered in such a unit.
A reader of my website sent me this unit and he wanted me to measure it.
(If you are from China, I believe that by seeing the photos, you can already understand what terrible things will happen later) ;););)
This is the dashboard:
All the above measurement results indicate that this is a garbage.
Even more frightening is that the manufacturer is a liar
Here are the measurements published by the manufacturer:
My suggestion: you should Never Ever Forever consider this manufacturer's products.
solderdude
The Neitherlands
What does it look like up to 200kHz or so ?
The grass between the harmonics may be folded back into the audible range due to poor filtering.
Can you measure/make visible the low pass filter (if present at all ?)
WolfX-700
WolfX-700
China
This is the NOS 1M FFT measurement made before:
I'll go to dinner first and come back to measure the filter characteristics
solderdude
The Neitherlands
Well they did not lie completely .... the S/N ratio is >120dB, even in the measured one.
They just don't tell you that it drops tremendously when it has to do something (as in play music or test tones).
WolfX-700
WolfX-700
China
Koeitje
Edit: I'm blind
bunkbail
