Review and Measurements of Benchmark AHB2 Amp
digitalfrost
Palatinate, Germany
Why have I never heard about this thing before and why does it have such good specs? What is their magic? @amirm should test this.
Someone should contact them first to send me one. ;) :)
D700
Its certainly winning the capacitor wars. Tidy kit as well.
anmpr1
Out of curiosity: is there still a critical mass of manufacturers who adhere to this FTC rule in 2019? I remember in the golden age of car audio there was CEA-2006...
I don't think the regulation is a requirment, anymore. In any case, the test protocol was always questionable, from a 'real world' standpoint. Prior to its adoption, David Hafler (among others) was a big critic. The original idea was to stop manufacturers from using idiotic, made up power ratings claiming huge numbers that had absolutely no relationship to the actual amplifier's capability.
FWIW, I have a David Hafler/Ed Laurent kit, a tube design from the late '50s. Modern up to date parts. Dyna rated them (EL34 mono amps) at about 40 watts. From an FTC standpoint it would probably be a 15-20 watt amp. But it sounds as powerful as my 100 watt/channel Yamaha SS, in real life and on real music. The FTC rule was ridiculous for tubes. Why would you want to stress tubes ala FTC protocol? What is that supposed to tell you?
Of course neither the Dyna nor the Yamaha sounds nearly as good or as powerful as my AHB2. I wouldn't pay much attention to the FTC protocol. Again, it was just an ad hoc thing that was made up to control out of control advertising claims, not to get to the bottom of what constitutes good amp design.
PS: from a quick search it appears that the original rule is not in effect, but has been revised. It now includes active speakers, or subwoofers. I don't know how it applies to multi channel AV type amps. I'm all for accountability in advertising. It's just that the FTC rule has to be seen within the context of advertising, and not whether an amp that passes the test is necessarily better than one that won't.
anmpr1
PSS: I came across another discussion that indicates the FTC rule only covers consumer Hi-Fi gear. Not professional oriented products, or musical instrument amplifiers. If that is so, it would be interesting to know the status of a product like the AHB2, which straddles the pro-consumer fence, or amps such as Crown, which are strictly pro-oriented.
headshake
Looks like a cheaper alternative amp to Benchmark is Denafrips Hyperion amp with 80 watts rms into 8ohms class AB, 0.00078% THD+N and 125 dB S/N ratio.
Attached link: https://www.vinshineaudio.com/product-page/denafrips-hyperion-poweramp
What a beast! So this is $50USD cheaper than an ncore DIY kit to my door and the only labour is taking it out of the box? Hmmm.
The "18 pieces of large reservoir capacitors (147,600uF)" ...oh my goodness. The Outlaw audio 2200 mono's have 20,0000uF. The "AT6007 7 channels (fully loaded) with 59,400 microfarads capacitance per channel."
Another review (that was prob translated):
https://www.denafrips.com/single-post/2019/05/29/Hyperion-Review
The current on tap from the amp seems high, so although 80 watts per channel into 8 ohms does not sound like much, there is drive and no little authority to the sound. There is a weight and body to the sound, a corporeal character that is really fleshy with vocal-heavy tracks, and is especially pronounced with bass notes; however, I have to turn up the volume when compared to my PS Audio M700 monoblocks (350 watts per channel into 8 ohms, 700 into 4), so for example for the similar approximate output at 50 on my preamp steps using the M700s, I have to go to 75 using the Hyperion.
ABH2 specs:
Ok, so this is where the Hypex DIY nc400 kit and the Denafrips Hyperion fall off a little for me: No trigger. I don't want to be a human trigger for amp power.
They all prob have different levels of falt protection. I'd bet the ABH2 has more.
TRIGGER I/O
  • 12 VDC 200 mA current-limited output to trigger turn-on of remote devices
  • DC input for slaving to remote devices
  • Input responds to 3.3 V logic and higher, VIL = 1.26 V, VIH = 2.7 V
  • Absolute maximum input voltage = 30 VDC
  • Absolute minimum input voltage = -0.3 VDC
  • Input Impedance = 20 k Ohms
PROTECTION CIRCUITS
  • Fully Electronic, No Relays
  • Mute Sequencing
  • Distortion Detection
  • Short Circuit Detection
  • Over Current Detection
  • Over Temperature Detection
  • SOA Detection (Output device safe operating area)
RichB
Massachusetts
Online, power calculators are not very good at determining the actual power requirements.
My Salon2's are 86 dB at 2.83 volts (about a watt) but since they hover around 4 Ohms, assume 2 watts.
To get a better handle, I measured the volume setting -31 on XMC-1 delivers approximately 2.83 volts (1kHz, 2khz, 50hz) at my seating positions which is about 10 feet from the speakers. My room is 4500 cubic feet, 30 ft. long with openings on the rear-left and rear.
Here are my typical listening levels and power:
Background Music: 0.5 watts
Typical Music: 2 watts
TV: 4 watts
Movies: 8 watts
Movies too Loud: 32 watts
Music Loud: 64 watts
Clipping Tests: 128 watts
Two Benchmark AHB2's are driving the Salon2 bi-amped.
According to my measurements and the AHB2 clipping indicators, I do not clip these amps at any level I care to listen.
When I had the ATI AT6000's their clipping indicators would light at -6 that support the accuracy of these values.
- Rich
Sal1950
The Chicago Crusher
Central Fl
Get one of these then. I use two of them to control the 5 Adcoms in my system. Turn on the pre/pro and the whole system comes up.
dkfan9
Columbus, Ohio
So powering down amps like this is not bad for them in the long run? Possibly I'm biased by TVs and other electronics that generally do not like this.
DonH56
Monument, CO
Most electronics have a switch that removes the power, same as the box does. And every power amp I've seen. Some have a soft-start circuit but they all just switch off power. Some have a standby mode, which you would lose, mainly to keep the trigger circuit alive (in the case of power amps) so nothing to lose in your case.
Sal1950
The Chicago Crusher
Central Fl
Todays TV's are "smart" devices, meaning they are computer controled. And like computers you wouldn't want to just kill power to them on a regular basis, not to mention having to wait for some boot-up period on startup. Power amps are just dumb devices and none of that would apply.
Forgot to link, at $25, very cheap.
https://www.adafruit.com/product/2935?gclid=EAIaIQobChMIi9fB2dya2gIVEp7ACh3tMQZWEAQYAiABEgJUQvD_BwE
RichB
Massachusetts
OLED TV's run compensation cycles in standby when the TV has at least 4 hours use. So, do not cut the power if you want them to perform well. For Amps, I prefer connecting them directly to the wall.
- Rich
dkfan9
Columbus, Ohio
Ok good to know--killing power at the device isn't inherently bad, it's all dependent on the device's requirements, and most "dumb" devices have no special power down requirements. Thanks all :)
Sal1950
The Chicago Crusher
Central Fl
Is that when the supposed fix for their ability to image burn-in the screen runs?
I'll be sticking with LED for now due to this issue.
RichB
Massachusetts
Each technology has its advantages.
OLED compensation cycles have more to do with residual images, banding in low APL areas.
It is not burn-in which is really uneven wear. If you watches stations with tickers, news most of the time, LCD is a better choice.
OLED is better than Plasma for IR and wear. For most, it is not an issue.
OLED's perfect black-levels and accurate color tracking provide an SOA viewing experience.
They are wonderful.
- Rich
RichB
Massachusetts
I bought a newer Fluke 115, good enough for my basic usage and level matching.
Level matching the AHB2 and ATI AT522NC, I noticed something odd.
The AHB2 measures 0 Volts with no signal and with the inputs removed.
The AT522NC measure consistently 0.08 volts with no signal and with the inputs removed.
It's not huge, but shouldn't the AT522NC be measuring 0 Volts?
- Rich
