Review and Measurements of Massdrop THX AAA 789 Amp
Music1969
Sorry we dont have those curves for 8 Ohms. But like all AAA, distortion remains extremely low even at high current. Peak current is approx 0.9Apk before protection invokes.
Also beware the limitations on driving low impedance like this. See the owners manual.
Thanks Andrew.
Is it safe to say the single ended headphone output can deliver 0.5A easily into 8 ohms planar magnetic headphones, with ultra low distortion (<<<0.1% THD)?
That's 2 Watts but it's the high current output (up to 0.5A) into 8 ohms low impedance I'm interested in, with ultra low distortion (<<<0.1% THD).
AndrewMason
Thanks Andrew.
Yes should be fine, and yes ultra low distortion.
mi-fu
New York
@AndrewMason , just out of curiosity, if I drive two headphones from the SE outputs on the 789 together, will it create any problem? How about the extreme case, driving three headphones together (one balanced output plus two SE outputs)?
AndrewMason
It's ok so long as a) the headphones have combined parallel impedance higher than the minimum impedance that the 789 is rated for, and b) you dont blow up your headphones (ie don't overdrive IEMs by accident while listening to parallel headphones with high voltage .)
mi-fu
New York
Got it! Thanks, @AndrewMason !
jsmiller58
Seattle metro area
@AndrewMason - combined as in parallel resistance calculations 1/Rt = 1/R1 + 1/R2 + 1/R3, or series Rt = R1 + R2 + R3... makes a big difference, particularly if the impedances involved are low...
Tup3x
Finland
How's the channel crosstalk? I assume it's good, especially when using balanced but I do wonder if that's the weakest point when using single ended output.
Gotta say that I really like the idea of <1x gain options. That makes life much easier with powerful DACs.
AresHarvest
Just want to point out he was explicit in saying parallel. "the headphones have combined parallel impedance higher than..." (emphasis mine)
AndrewMason
Yes, all the headphones will load the power amps in parallel. Not series.
jsmiller58
Seattle metro area
Yeah, I saw that. Just not sure if everyone has done the math. Very small effective load will resut in many cases, possibly violating the spec.
Roen
Sorry, what is that minimum impedance that the 789 is rated for?
mi-fu
New York
btw, just looked at the massdrop page, there are only 18 units left. :eek:
Veri
Hope that's not true God effin damn it,
I am still post-poning my purchasing it :p
L-Train
Hi all, I just wanted to give an update regarding the crosstalk at the lowest gain. It occurred to me, since I had to put the volume control at 4 o'clock in the test that had the crosstalk issue, perhaps it's the potentiometer that's causing it. So I did another test, this time with gain setting "2", with 20 dBu input and the volume set to 1-2 o'clock to reach 6 dBV output, and I get a similar, albeit lower, increase in crosstalk!
So it looks like the increase in crosstalk is caused by the potentiometer (and varies with the position of the potentiometer), and not the gain setting.
