Review and Measurements of Massdrop THX AAA 789 Amp
jsmiller58
Seattle metro area
You bought two??? No wonder there is a shortage. :D
I agree. For its performance, it has a very reasonable price.
Amir - based on your experience in measuring amps, what would you say the best performing amp is for $500 or less? Best if has both SE and balanced outputs, but since price/value will probably be very different, what about best SE only, and best SE and balanced combo?
bakker_be
Belgium
Just go Massdrop to request. Once they hit a critical mass number, they will re-open the drop.
Its pretty standard on almost all their popular stuff.
I just did, there's more than 600 requests at the moment :)
rajapruk
Right now it is 2845 requests, 14 minutes later. Can it be true??
bakker_be
Belgium
I still see 612, right now
andymok
Hong Kong
They will make it to regular item eventually. I think they're just making use of these "one-time drops" to start manufacturing and stocking it, so that when it turns into a regular drop it will be available immediately.
at least that's my impression from SDAC
maxxevv
Bizarre ...
The 600+ are from the current requests.
The 2800+ are the cumulative requests from across the last 2 drops that have completed and further requests (including the 600+) since.
They probably display different for different parts of the world. I only see the 2800+ numbers.
pos
@amirm, can you please test THD vs power level with a lower load on the balanced output (16 ohms, and maybe lower) ?
I would be curious to see how this amp react when the current limit hits.
mastershake
im glad i ordered 2 also. but the first one i got has some power button issues. and a few others over at head fi say the same thing. also the gain knob on my first one is not centered at all. on I its more like II and then the second detent at what should be II is almost at III. i mean it clicks at each detent but its annoying lol. im pretty sure i read a response at one point where cee tee had said they will re drop them again. if they do i may even grab a third for the office. im considering the monoprice unit but im not sure if i really want the dac built in or not a decent price though for the combo unit.
FrantzM
Just waiting for this drop and nabbing it ... Not that I need one more headphone amp or DAC but ... We can all indulge a bit..
I notice them mentioning the ASR review . Long Live The King!! ..... and His Followers ...
Jimster480
Tampa Bay
Do you mean SE output, input..? He briefly touched upon SE amplification performance
"You simply get copious more power at whopping level of 3.5 watts before clipping." >> the lines fall on top of each other until SE clipping point, so as long as you don't run out of headroom, SE performance is identical.
He has no balanced headphones right now so the subjective testing was all done via SE (as well as the khadas tone board input, connected via SE), showed no audible distortion whatsoever.
No man, I meant sinad, thd, dnr.
It does say on the manual that comes with it that single ended performance is worse.
The question is how much worse.
Confirming, when you say single-ended, you mean RCA inputs and not the headphone out?
Hurricane Alley
The Monoprice unit states dual THX AAA 788 amps. Same as the Massdrop '789' ? The real question is the implementation of the dual AKM4493 chips. As amirm has shown in many tests, just having a name DAC chip does not mean automatic success. The components upstream and downstream from the chip are just as important. However at the price of $479.00 against $499.00 for a DX7s this is very attractive. Can't wait for a review.
I think Topping choosing a AKM chip for the DX3Pro might give a clue to future Topping products. What could Topping do with the THX chips?
Speaking of Massdrops long lead times, and yes I have waited too, remember the very contested R-2R DAC from back in, what, July? Those folks are still waiting for first shipment! Now that would be a DAC for amirm to test.
