Review and Measurements of Massdrop THX AAA 789 Amp
raistlin65
Grand Rapids, MI
Asgard 3 is not class A, so sort of like a CFL to your LED bulb.
Okay. So upon further research, it appears it is Class A up to the first 500 mw at 32 ohms. So about half as much power usage in idle as the Asgard 2, but maybe a order of magnitude more than a low bias full class AB. I think I'll hold out.
raistlin65
Grand Rapids, MI
It's outside my electronics skills (zero) but I think the max output voltage is the easy part to calculate.
So I started plowing through the whole thread, and discovered this graph from Amir which shows the voltage and SINAD with 2V unbalanced input and single ended output
https://www.audiosciencereview.com/...sdrop-thx-aaa-789-amp.5001/page-4#post-111966
That's plenty of voltage output for my needs. Time to order!
phoenixdogfan
Nashville
I bought it over a year ago now. Some thing exceed it by 1-2 db of SINAD and a little more power, but, for all intents and purposes, this amp is perfect for any use case I could imagine.
Viper Necklampy
I don't understand some things thing about max voltage, especially with those THX amps that has no findable specs;
Does the 6V max voltage level connected with 2V dac, are referred with normal gain in (1.0x gain, 0dB) output? Does it mean that with high gain in SE output (3.3x gain, +10dB) it will be 6V x 3.3= around 18V Maximium voltage? But i don't think this amp can reach 18V at maximum, there is very little info about, but i think i understand it is capable of max 11-12V (maybe at 300 ohm), not sure at all tho. 'Maximum Output Voltage, 11.5 Vrms into 300 Ohms', like Benchmark HPA4 THX amp. I have the 887 now but i used to have 789 before, they should share the same specifications.
Correct me if i'm wrong above, anyway... would be with balanced 4V dac's on balanced output with medium gain, double the maximum current? And the headphones most users will use would be 32ohm or lower, this what i will own at least, no chanches to detect if max output voltage would be higher around 32 ohm, vs 12V max at 300 ohm (Again, not sure about the max voltage spec)? Thanks in advance, hard to check online about..
Rottmannash
Nashville
I believe the 887 is a more powerful amp module than the 789. Since you own or have owned both amps which do you prefer?
Veri
The 887 is only a tiny bit more powerful than the 789 ;) in practice they're about the same.
Viper Necklampy
I changed dac and i'm not liking the current dac i have so i am waiting an ESS Soncoz LA-QXD1, since then i can't describe it more specifically sorry. I used to have the Topping d50 before and was very happy with 789. So i'm feeling the sound of 887 feels thicker vs the thinner 789, again i'm not 100% sure because of equipment used. But it will have 2W more power in balanced on 20ohm cans so not bad for that, better specs and a nice amount of lower output noise. I'm not sure if that 'thickness' which is nice, could end up on some detriments about speed, bloom, but probably not, just wondering :)
Rottmannash
Nashville
Good to know. Thanks for the clarification.
Rottmannash
Nashville
Is this the Monolith 887?
Veri
The dashboard linked is single-ended 6.6V at max gain (2.0V at x3.3 gain = 6.6V ;) ).
Using balanced input will effectively double the output, but note that gain level III will now show clipping behaviour! Read the manual about this. On the other hand, using balanced output will quadruple the output like so: (0.9W => ~3.6W).
Viper Necklampy
Oh thanks for the nicely sharp reply :D That's makes lot of sense.
About Wattage, the gain multipliers of unbalanced/balanced are always valid for every ohm avaiable for headphones?
And i'm a bit of a fish when it comes to Voltage numbers, so let me ask: If using a 4V dac and medium gain> 2.0x (+6dB) for avoiding clipping in most cases, this would be 4V x 2.0x gain= 8V Max voltage? A harder question: With max gain on balanced output, with balanced 4V dac (Tho clipping risks) 6.6x gain x 4V= 25Vrms > Will it reach 25V, or is it limited to lesser?
Veri
-Well yeah, the sensitivity of the headphone will determine the loudness that translates to.
-Correct. Max gain balanced is a tough one though, I don't know since it will crap out somewhere along the way, so not advised.
Note that single ended max gain (2V => 6.6V) is still less powerful than balanced middle gain. What are you driving, anyways?
Viper Necklampy
25V max output voltage on 'clipping' high gain for THX 789? That's really hot if true..
Well for now an M1060c, than i would LCD-XC someday, guess both don't require much Voltage to perform well. But would also like to get back the Hifiman HE1000v2's as soon, so that's maybe harder to drive, but not insanely. Even tho i cannot find any specs for headphones requirements of Voltage, maybe it's the xxxdB/1V specification; instead Wattage is easy to determine in few search... So i yet to read all the sorderdude's tutorial https://diyaudioheaven.wordpress.com/tutorials/power-impedance-etc/ to understand the Voltage spec and the requirement of headphones.
I just like to have extra headroom than normal, that's why i also got 887 for 2W more watt at my 20 ohm planars, even if 8w instead of 6w is tiny more headroom. Would like to know on the voltage side, since i know planars need lot of headroom not only in Wattage, but Volts, the big ones are pretty demanding of power.
jawbfl
Morocco
I'm looking into acquiring a 789, but I don't plan to get a DAC for now, if I connect it using 3.5mm to RCA will I get the benefits of balanced output? or balanced output requires balanced inputs?
raistlin65
Grand Rapids, MI
What do you think the benefits are of balanced output and why do you need it?
A lot of people don't really need balanced, but seem to think that they will drive some sound quality benefit from it.
Moreover, there are single ended amps that will drive 99% of headphones and offer the same sound quality for less money.
So what is it about the 789 that you think you need?
jawbfl
Morocco
I understand your points, for my current needs the Atom is perfect but I have a different reasons to consider 789:
- Due to current pricing/shipping/customs what I will pay for a new Atom can get me close to a 2nd hand THX
- In my country I can't resell audio equipment, the market doesn't exist. So I'd rather get something that I would use for as long as possible, 789 with a good DAC can drive almost any headphones or speakers I might get in the future, so I don't have to buy new gear and have old gear that I won't use or sell.
raistlin65
Grand Rapids, MI
Just to note that a headphone amp can't drive speakers. Only a speaker amp can do that.
But if you mean you want the capability to hook up active pro audio speakers, that is a good reason to go with a balanced setup. Some pro audio speakers (e.g. JBL LSR series) are prone to picking up PC noise when used with unbalanced connections. But with other speaker setups, unlikely to help.
As for the notion of being able to drive almost any headphones, the headphone community always moves to the latest, most powerful amp and hypes it that way, as well as promoting the general sentiment that balanced is the only solution for driving difficult headphones.
Single-ended amps such as the Schiit Heresy come very close in headphone amp performance to the 789. And even the Atom has sufficient power to drive 99% of headphones.
So personally, I would not focus on "balanced" since you are looking at the used market. There are many amps, some of which are not balanced, that can meet your needs for driving future headphones. I would look at everything about an amp.
