Review and Measurements of Schiit LYR 2 Amplifier
bravomail
Thx for review, Amir! If anything, headphone manufacturers should flock to Schiit and ask it to do more devices like Lyr 3, to increase headphone sales! :) :D
Dana reed
Where did you get those tubes? After I get this amp back from Amir, I may try some tube rolling.
Sadly, I don't have any other tubes for this amp (yet). I have been using it exclusively with LISST after I found that I subjectively preferred their sound. Curious to see that Schiit have now discontinued them, I wonder why?
I got the tubes here, and sprung the extra few bucks for a matched set
https://www.tubedepot.com/t/brands/genalex
They discontinued the LISST at the end of last year because they didn’t sell well and were a pain to assemble. Oh well, I have a pair of them for this amp and also four of them for my Freya preamp. They should last for a while being SS.
Jimster480
Tampa Bay
The measurements are "okay" but honestly the price is too high.... and as some others have said; this unit has been reported to kill headphones.
Better to stay away from something that could possibly kill headphones (or your hearing) if there is a problem...
garbulky
It was grounded. I assume output impedance is independent of input gain.
I'm just curious how they are managing the low gain. If it is by means of a resistor the output impedance might be particularly high in low gain mode.
solderdude
The Neitherlands
In case of the Lyr2 (which is a hybrid) the output impedance is low in both gain settings.
It is below 0.3 Ohm in both gain settings.
Output Impedance: 0.3 ohms, high gain (worst case)
With the Valhalla 2 the gain settings do affect the output impedance directly, more feedback = lower gain = lower output impedance in this particular case (single ended tube output)
Output Impedance: 14 ohms (high gain), 3.5 ohms (low gain)
Electrohm
Weird...
I have a Lyr 2 and it sounds super clean yet powerful to me...
I would have guessed that it measures way better than this in the Sinad department
Dana reed
Weird...
From listening you probably would never notice a 2nd harmonic at -90 dB. The only headphones I don't use with this thing are IEMs, since I can hear the noise floor with those. But who knows why I'd even try using IEMs on something that can put several watts into them? It rocks out with a pair of Beyer T1s.
Cosmik
It is possible though that DC could appear on the output (resulting in a loud and sharp 'tick' when the relay kicks in) that could destroy headphones.
Add to that TH-X00 drivers are 25 Ohm and the Lyr-3 can deliver peaks in excess of 8W in it (when something bad happens)
I find this sort of thing incredible. Someone could easily plug in-ear headphones into this thing, and whether or not it was the amp that went wrong or what was feeding it, the idea that something non-'medical grade' and potentially >8W is connected to something right in your ears seems... foolhardy. If the noise doesn't get you, the flames will. Maybe headphones are inherently fused..? Do we know that? Do we know that 'boutique' headphone companies know that they should be fused..? I doubt it. Why do people trust the design skills of these people at all, given their track record?
Electrohm
well not that you put it like that...
Second harmonic at -90db doesn't sound bad at all.
The graphs just make it look allot worse
But I'm more used to looking at the DAC graphs which usually looks allot less messy for a good porduct
Electrohm
The excess power is so you can be sure whatever power hungry headphone you plug into it it will power it properly
Especially low sensitivity, low impedance Planars.
Those need immense power to sound as good as they can.
Dana reed
Indeed, it also works really well with my HE560, and even Aeons. Though I think I like the Aeons better with the THX789 or Jotunheim
solderdude
The Neitherlands
Yet many people all around the world plug their headphones in these type of amps expecting to hear beautiful music.
Chances that your amp fails in a way that one of the supply rails voltages (in case of an error and certainly with amps using global feedback) is very small but not imaginary. A very simple DC protection circuit would not prevent the amp to go faulty but at least protect your headphone.
In the above case one would hear a short loud 'tick', no fire and most likely not even smoke. Just a driver that doesn't work any more.
I know of no headphones with fuses. It is not needed either as the voicecoil wires are so thin these burn out quickly. Only some high power rated headphones >1W are likely to let out some magic smoke. My old Beyer DT990 had (I removed it) over voltage protection which only works correctly when the source impedance is high or the current is limited. This consisted of 2x 12V diodes (1.3W) in anti-series.
That is indeed a good question. I guess the many many positive reviews, high power ratings and relatively low costs and/or wanting to buy US made gear could be deciding factors. Outside of ASR most folks tend to like Schiit stuff.
Cosmik
That was what I was thinking of when I said 'inherently fused' - but is it guaranteed? Guaranteed not to generate a large amount of gas, toxic fumes as it burns out? In your ear.
Jimster480
Tampa Bay
This would be the opposite for tube amps.
Typically tubes fail at delivering current into low impedance.
solderdude
The Neitherlands
In this case you would be referring to IEMs which usually have a power rating of just 10 to 20mW or so.
The wires inside are so incredibly small they would burn out immediately. Too short of a time to burn plastics etc.
Besides... I think no one in their right mind would connect a low imp. IEM to a LYR.
The few drivers I managed to destroy all went silent unnoticed. They just stop playing. No other signs anywhere.
Its not like woofers connected to mains which can be quite spectacular.
solderdude
The Neitherlands
What would one call immense power ?
