28 pages here, probably this has been already said, but worth an update: reason for having the exact same output power when switching from unbalanced to balanced is that the amp itself is not fully balanced. There is an
OPA1612 at the RCA inputs which takes care of both Left & Right unbalanced signals, and for the balanced XLR inputs there're 2 x
OPA1612 that are converting the unblanced for feeding the
OPA564.
Seems that
@yummy already "discovered" this
here, but also other ASRers found this info as well, although worth mentioning again Benchmark's thoughts about balanced headamps:
https://benchmarkmedia.com/blogs/application_notes/audio-myth-balanced-headphone-outputs-are-better:
"Benchmark does not offer voltage-balanced headphone outputs on any of its products. The reason for this is that a voltage-balanced interface serves no useful purpose when driving headphones. The truth is that a conventional single-ended headphone drive is technically superior to a balanced drive. This paper explains why single-ended headphone amplifiers are inherently more transparent than balanced headphone amplifiers.
We do offer a 4-pin XLR connection on the HPA4 headphone amplifier, because this 4-pin connection offers lower contact resistance than a traditional 1/4" TRS connection. For performance reasons, this connector is not driven with a voltage-balanced signal. Instead, it provides isolated left and right ground returns that are individually connected to the ground reference points in the left and right amplifiers.
Please understand that Benchmark strongly encourages the use of balanced line-level interfaces between audio products. All of our products are equipped with fully-balanced XLR analog inputs and outputs. In these box-to-box line-level connections, a balanced interface can provide substantial performance improvements. Balanced line-level interfaces reject hum and noise while providing a higher voltage level. The higher signal levels can improve the SNR (signal to noise ratio) of the audio system".
I'm personally only 90% inclined about what Benchmark engineers says, but I'm sure they're right.
As a side note,
THX 789 has two output buffers per channel, the same
OPA564 operational amplifiers, but each one is used to amplify the "hot" signal from the balanced signal.
However, like Amir stated, SP200 has enough output power and it has an extremely low-noise, so as long as this headamp can accept balanced interconnects (it's hard to pass 10m long with RCA cables and not inject some of the noise), then the most important aspect of purchasing a balanced amplifier is already achieved.
Some photos I found today on apos website:
https://apos.audio/products/smsl-sp200-thx-headphone-amp. Seems that
@Veri found this website too, so I'll provide direct links from their CDN servers:
