Review and Measurements of SMSL SP200 THX HP Amp
RayDunzl
Central Scrutinizer
Riverview FL
wassim01
update : after testing with a lg g5 phone ( 2016 ), this SP200 sound amazing, The sound stage amplifier is wide, it is clearly natural and open, it’s the best sound I’ve ever heard before, it’s bizzard than my dac ifi zen n not a good performance compared to my lg g5
Veri
that's a top of the line amplifier for ya ;)
wassim01
thank you for your involvement and your advice. now i am looking for a good dac, but i can't decide between smsl m300 mk2 (247 euro), smsl su-v2 (210 euro) and topping d50s (250 euro). If anyone can advise me which of them sounds the best
Veri
I honestly think all three are great. Do you maybe need balanced in the future? Then M300 or SU-8 makes more sense.
Do you want bluetooth? D50s.
wassim01
i think i will take smsl m300 mk3. the smsl m300 uses a single ak4497 chip but the topping d50s and smsl su-8 use two es9038q2m chips. this makes a difference in the sound quality between these dacs ?
Veri
No.. theoretically there might be a small crosstalk benefit but in reality there is little to no difference between 1 or 2 chip.
Having two chips is easier for marketing though. '2 is better than 1'. In reality, not much of a point for 2-channel audio. Really..
wassim01
thank you so much
Rigel
Interesting. Thank´s for the link.
Maybe I have not understood well by the language. I thought that even if the headphone output was not balanced, the signal processing was done separately. I thought I read it before in some post. But it seems that the mass is shared for the two channels.
In Benchmark HPA4, it seems that the masses would be separated to the amplifiers of each channel even if the voltage is not balanced.
olinko
quick question, I've heard that using one of these to plug unbalanced headphones into balanced is bad, but is it okay if it's not a fully balanced amp like the SMSL SP200?
Veri
That is a 3-pin converter. Converting 4-pin (2x hot-cold, fully balanced) to SE can short your amp and possibly even damage it.
But yes, the SP200 is not truly balanced so it only uses 2 of those pins. Why you'd use an adapter is not clear to me though, since you'd achieve the same thing plugging it into the single ended output right next to it. Exact same thing.
It would make far more sense to use an adapter/cable to convert your balanced headphones and connect them single ended, rather than using an adapter on your balanced amp. That's generally a pretty bad idea.
olinko
This is just so I can have two headphones plugged in, both are 3.5 mm.
So converting 3.5 to 4-pin specifically on the SP200 can still cause a shortage?
Veri
On the SP200 it should be harmless :) I understand your use case now. Should be fine! Make sure it's 4-pin though.
olinko
My mistake, didn't look at the picture thoroughly enough
Thanks a lot! :)
frogmeat69
Western New York, USA
Doesn't the M300 Mk 2 have Bluetooth? If so, that might be the best all around choice for value and options.
Incursio
Japan
I was on the fence as to whether to get this amp or not, and I did.
What swung me was that it reminded me of the control panel of the Mandalorian's space ship, the Razor Crest.
Also, that slight case lean to the right. I like that.
"This is the way."
