Review and Measurements of the Chord Hugo 1 DAC & HP Amp
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
The difference between Chord and companies like PS and TotalDAC is that behind the asinine ramblings and snake oil feeding tendencies of Watts, Chord are actually technically very accomplished and know what they are doing. Crazily expensive IMO and not worth it but if you are going to dabble in expensive gear then at least Chord stuff tends to be well designed.
Agreed on Chord. They don't make Schiit. Auralic seems to be in that category of high price but high performance as well.
I'd like to see one of their newer models tested.
typericey
Thanks Amir.
Maybe if there's a really good deal on a used one, then yes.
Those who already have one now have a reason to keep it (and sleep a little better at night).
Curious if you can eke out a bit more performance out of it at 2V.
I have heard horror stories on batteries going bad and Chord charging a lot to replace them. So be careful with used or old ones. Spec says "custom" Lithium-Ion battery.
Jimster480
Tampa Bay
While the performance of this is quite good, I don't think that it offers any real perceivable difference in performance vs an NX4 DSD which is ~140.
JJB70
Singapore
Indeed, you really don't have to spend much at all to get an audibly transparent DAC and headphone amplifier. Many devices have perfectly acceptable on-board DACs, the Apple dongle offers excellent performance for $9, and for headphone amplifiers the JDS Atom offers brilliant performance for $100. We live in great times if you just want access to great SQ.
Frank Dernie
Oxfordshire
The machined from solid case and fancy lights are probably a significant part of the cost.
I have one but stopped using it when I found my phone was powerful enough.
I tried it in my main system and, as one might expect, it sounded the same as the others I tried.
It was pretty well the only portable amp/dac available here at any price when I bought mine.
Edit
I rather like the colour of the lights changing with volume and sampling rate the volume control and "porthole" fwiw
ShiZo
Do you think they'll ever include xlr outputs for speakers and headphones?
Frank Dernie
Oxfordshire
Probably not since this is made for portable use.
The desktop version has xlr line outputs as well as rca. The headphone jacks are 2x ¼" and 3.5mm.
LLL
Seattle, WA
This is a great example of the Brand Value. Just like a Birkin bag, is there any handbag out there that you think really worth over 5-figure? No.
You pay = Utility value + Brand value...
At least Chord doesn't engineer crap.
LuckyLuke575
Germany
I tested a Hugo 2 a while back but it was with my old analyzer. So a member kindly sent me an original Hugo DAC and headphone amplifier to remeasure. I wa shocked to find out that the Hugo cost US $2,500 when it came out!!! Man that is expensive for a portable DAC and Amp.
Here is a shot of it if you have not seen it:
I can't stand the lights you have to have a decoder ring to decipher. The tiny power slider. General lack of labeling, etc.
For this testing, I took advantage of putting the RCA out at fixed level so there is no complaints about using volume control. Speaking of volume control, the rotary plastic knob is super stiff to turn. Not sure if they degrade to this or came this way. Definitely does not feel good. But I guess if you put it in your pocket it won't change on its own easily.
Anyway, the purpose is the measurements so let's get into that.
DAC Audio Measurements
I tested the DAC portion by feeding the Hugo using USB and measuring what came out of the RCA jacks using fixed line out mode:
As you see, the Hugo outputs that oddball 3 volt. It is not a bad thing but is more than nominal 2 volt we expect. Performance may be better at 2 volt but as it is, the SINAD (signal over noise and distortion) is quite good for a portable product at 109 dB:
Jitter performance was likewise good other than a couple of inconsequential spikes:
Chord's claim to fame are very large tap filters. We can see their response by feeding the DAC white noise and see what comes out after fair bit of averaging:
I like the super sharp cut off at required bandwidth (22.05 kHz). There is some relaxing after a while which should be fine. Certainly better than a lot of DACs which take their time to get to 24 kHz and beyond.
Linearity was perfect:
IMD results show a bit higher noise level than our reference but otherwise is good:
Dynamic range is very good as well:
Headphone Amplifier Audio Measurements
Let's start with signal to noise ratio at full output level (which clipped horribly) and just 50 millivolts:
Full range is fine but 50 millivolt is not that great:
There is likely some hiss with sensitive IEMs.
Most important here is THD+N versus power. Let's start with 300 ohm load:
Was surprised that at the high gain of the amplifier causing the graph to start pretty late. My testing is at full volume though so in practice, you can reduce the level and be fine.
Power is good at 65 milliwatts. Certainly a lot better than a phone or dongle.
Switching to 33 ohm we get:
Noise floor+distortion rise fair bit now. But we still have plenty of power for a portable product at nearly 0.4 watts.
Output impedance is quite low and hence good:
Typical of Chord products, even the version one of Hugo is competently designed, approaching performance of desktop DACs. As noted though, I can't stand their user interface, the looks, or the sky high price. So can't recommend it personally but you have the data to use as you see fit.
I have been doing so many reviews I am fresh out of lame jokes. So I make this simple: Please donate money using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Amir
$2500 for this???? Bring out the smelling salts...
Whenever I see pics of these units posted on forums, it always feels like people trying to show off. I guess it's positioned like luxury item or something.
Reactions: LLL
Hemi-Demon
If Chord would just add standard XLR (instead of BCA), and list the device at $999 as an all in one, portable. The dap market would be dead. The Hugo 2 and Hugo 1 both sound great, but the price is just ridiculous.
Music1969
Well the design engineer for their current model DACs is Rob Watts. So I would say Rob Watts doesn't engineer crap.
Would be interesting to see how Chord's non-Rob Watts products measure, like their amps. They are super expensive though.
AudioSceptic
Northampton, UK
Amir
I'm sorry, Amir, but your conclusion is really inconsistent. You have recommended other products with high prices and barely adequate performance. The Hugo was expensive but its performance is much more than adequate, and was there another product as good or better for the money in 2014?. I feel you have let your dislike of its styling and interface, which some welcome as a relief from the boring "me too" mainstream, overcome your normally objective judgement.
AudioSceptic
Northampton, UK
By "all in one" you mean with storage as well? Without that it's not a DAP. But Amir wouldn't like it even at $500...
Veri
It's 2019. Recommendations are for present use or purchase.
AudioSceptic
Northampton, UK
Is it still available new? It's been replaced by the Hugo 2, so its value should be judged as a used item.
In any case, in other reviews Amir has ignored the price of expensive (overpriced?) products and still recommended them because they performed merely adequately.
JJB70
Singapore
This is a luxury item, it exists in that segment where desirability and willingness to buy are not necessarily a function of performance. Nobody needs to reach the level of measured performance delivered by companies like Chord and Benchmark or the luxury build of companies like Accuphase or Luxman or the style and image of Macintosh etc. However people may very well want these things and if they are willing and able to pay for them then I can think of sillier ways to spend money. I am not into a lot of this stuff but there are high end audio goods I would be happy to buy, such as Accuphase or Benchmark. I would not be buying them for SQ but for other entirely subjective and personal reasons. If you want great SQ, especially from a DAC and headphone amplifier you can get tremendous sound for peanuts.
However if sound is a factor in reviews then I think we have to be consistent. No way is the price of this items justified by the SQ but I would argue that is equally true of all other high end DACs and headphone amps, including Benchmark, Violectric, Matrix etc. If viewed as a luxury good then the criteria changes. People don't buy IWC or Breguet watches just to tell the time.
ShiZo
Yeah amir is being disingenuous @AudioSceptic. Paying $10,000 (dave) instead of $1,000 (rme adi 2 dac) for a comparable dac is totally worth it.
