Review and Measurements of the Chord Hugo 1 DAC & HP Amp
I tested a Hugo 2 a while back but it was with my old analyzer. So a member kindly sent me an original Hugo DAC and headphone amplifier to remeasure. I wa shocked to find out that the Hugo cost US $2,500 when it came out!!! Man that is expensive for a portable DAC and Amp.
Here is a shot of it if you have not seen it:
I can't stand the lights you have to have a decoder ring to decipher. The tiny power slider. General lack of labeling, etc.
For this testing, I took advantage of putting the RCA out at fixed level so there is no complaints about using volume control. Speaking of volume control, the rotary plastic knob is super stiff to turn. Not sure if they degrade to this or came this way. Definitely does not feel good. But I guess if you put it in your pocket it won't change on its own easily.
Anyway, the purpose is the measurements so let's get into that.
DAC Audio Measurements
I tested the DAC portion by feeding the Hugo using USB and measuring what came out of the RCA jacks using fixed line out mode:
As you see, the Hugo outputs that oddball 3 volt. It is not a bad thing but is more than nominal 2 volt we expect. Performance may be better at 2 volt but as it is, the SINAD (signal over noise and distortion) is quite good for a portable product at 109 dB:
Jitter performance was likewise good other than a couple of inconsequential spikes:
Chord's claim to fame are very large tap filters. We can see their response by feeding the DAC white noise and see what comes out after fair bit of averaging:
I like the super sharp cut off at required bandwidth (22.05 kHz). There is some relaxing after a while which should be fine. Certainly better than a lot of DACs which take their time to get to 24 kHz and beyond.
Linearity was perfect:
IMD results show a bit higher noise level than our reference but otherwise is good:
Dynamic range is very good as well:
Headphone Amplifier Audio Measurements
Let's start with signal to noise ratio at full output level (which clipped horribly) and just 50 millivolts:
Full range is fine but 50 millivolt is not that great:
There is likely some hiss with sensitive IEMs.
Most important here is THD+N versus power. Let's start with 300 ohm load:
Chord Hogo DAC and Headphone Amplifier Power into 300 ohm Audio Measurements.png
Was surprised that at the high gain of the amplifier causing the graph to start pretty late. My testing is at full volume though so in practice, you can reduce the level and be fine.
Power is good at 65 milliwatts. Certainly a lot better than a phone or dongle.
Switching to 33 ohm we get:
Chord Hogo DAC and Headphone Amplifier Power into 33 ohm Audio Measurements.png
Noise floor+distortion rise fair bit now. But we still have plenty of power for a portable product at nearly 0.4 watts.
Output impedance is quite low and hence good:
Typical of Chord products, even the version one of Hugo is competently designed, approaching performance of desktop DACs. As noted though, I can't stand their user interface, the looks, or the sky high price. So can't recommend it personally but you have the data to use as you see fit.
I have been doing so many reviews I am fresh out of lame jokes. So I make this simple: Please donate money using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Amir
headwhacker
Thanks @amirm. I supposed it’s not bad especially when it first came out. I got it at a steep discount when the shop was clearing their stick of hugo 1. Still it’s amazing to think that a tiny e1da 9038S can beat Hugo 1’s performance at a ridiculously small fraction of the cost.
maxxevv
Considering that it is a few years long in the teeth, it was probably close to SOTA at its point of release.
But the pricing is the big bugbear indeed.
Rem
Damn that is really expensive for what it offers. I'm assuming the hugo 2 is somewhere near this too. I can't imagine buying a lot of $1k+ amps/dacs without seeing measurements first.
From what I heard ES100 is really weak like 4mw into 300ohms?
phoenixdogfan
Nashville
Way too expensive. Might be a cool get if you can find one at a steep discount used. (Provided you like the look and don't mind the interface)
headwhacker
This is why ASR is so valuable. I was very curious at the time that when an opportunity comes to buy the Hugo 1 at a steep discount albeit still expensive, I bit the proverbial bullet and opened my wallet.
headwhacker
2014 feels like ages ago. But indeed at the time, for a portable device it has the performance and the power. It was supposed to drive the HD800 and other high impedance headphones easily. Five years later, we have more affordable and arguably better choices like the 9038S from E1DA for cheap change compared to what the original Hugo initially cost.
peng
Amir
Good morning Amir, why is the Chord Mojo not included in the headphone amplifier 50 mV SNR chart, didn't you measure that one too?
maxxevv
Yup, there probably weren't many if any DAC's back then that measured "obviously"better. The only one that had some semblance of good measured performance on the DAC side seemed to have been the Anedio D2. And that was a US$1500 device too.
That wasn't yet on the list markers measured at the time of testing.
tsanguine
Salem Oregon
Yeh, I need to review the ES100. For now, I have to finish the gear that is loaned to me. This one I think was sent back in May!
I assumed you had given up on the es100. I keep checking back daily to see. I thought I recalled you having issues with it and maybe it just wasn't cooperating. Mine can occasionally be finicky. You were saying how you had it and wanted to measure it in April when I sent in the Sony UDA-1.
JJB70
Singapore
The difference between Chord and companies like PS and TotalDAC is that behind the asinine ramblings and snake oil feeding tendencies of Watts, Chord are actually technically very accomplished and know what they are doing. Crazily expensive IMO and not worth it but if you are going to dabble in expensive gear then at least Chord stuff tends to be well designed.
Ron Texas
Way expensive, but at least it works right.
antdroid
Reviewer
Seattle
These are selling used for significantly less than the original price now.
