Review and Measurements of Topping D50 DAC
CTRLM
I just leave it on 00.0dB....which is 100% (no attenuation) and use my integrated amp volume.
Reactions: MWC
andreasmaaan
When connecting the D50 to an external amp can you fix or disable the volume control?
I'm not sure what you mean by "fix"?
There shouldn't be any need to disable the volume control because it's the ESS onboard digital volume control. So it won't corrupt the signal in any way to have it enabled and set to 0dBfs.
deniall83
Australia
I mean fixed as in a fixed line out as to not cause problems when running through another volume control.
andreasmaaan
Ok cheers. Same answer - setting the volume at 0dB on the DAC will not affect the sound quality in any way :)
rdodev
It is amazing that there is a DAC that is $249 that when measured is far superior to DACs costing 10-20X more. Boy, something is really wrong in the audio industry. I am so glad I found this forum. Kuddos Amir!
Indeed. As said in a different thread. Nothing gives me the heebee-jeebees in the audiophile stack than DACs (specially at the high end). Lots of snake oil rhetoric and marketing speak going on.
Reactions: MWC
Tried updating the firmware. Before the upgrade it showed v6F2. After upgrade its showing the same version. Am I doing anything wrong. Firmware file says 1.8G
derp1n
Unless you saw an error during update, it worked. That's the expected behavior, unfortunately.
derp1n
gvl
SoCal
Likely v6.F2 is the revision of the actual hardware, it is not going to change. Is there a diagnostics screen on the DAC itself?
CTRLM
Mine's still sounding great, the only minor issue is that it doesn't display the bitrate - it's always on 00Bit.
I have a Chord Hugo 2 to audition over the next couple of nights so it's going to be interesting to do an informal comparison.
Same issue with my unit as well.. Displays 00Bit
Ron Party
CPH (Chief Prog Head)
Oakland
Are you seeing the 00Bit on the front display of the D50?
I'm playing a SACD rip of Shostakovich Symphony No. 8 right now. Mine states DSD64, 2.8 MHz, 1Bit, just as it should.
Toku
Japan
00Bit display is only for PCM Optical / Coaxial connection. It does not occur with USB connection.
CTRLM
Well that explains it, I'm using PCM & coax. :)
Toku
Japan
The second D50 ordered to Aliexpress arrived, and we compared two D50s immediately. I ordered from the Takstar Audio Store again this time, but the item arrived in just 4 days from the order. It is early. Massdrop took three weeks to deliver SMSL SU - 8 to me.
The SN of the first D50 bought in March is 1710xxxx, and the firmware has already been updated. The SN of the second D50 delivered this time is 1807xxxx.
The two D50s should have exactly the same behavior, but when comparing it is not the same with the connection in USB ASIO (Native) mode.
The noise that occasionally occurred in PCM 768 k or DSD is not generated at all in D50 of new SN 1807 x x x x. Obviously there are differences in the behavior of the two D50s. I do not know the cause, but I imagine that some changes have been made to the hardware as well.
