Review and Measurements of Topping DX7s DAC and Headphone Amp
Jonny
Here's what I wrote about this back in September post #272 re my iMac via USB using DX7s:
I also wanted to report on interesting findings on using Audirvana and HQPlayer/Roon on the DX7s via USB on an iMac. My music library is mostly ALAC 44.1/88.2/96/176/192. On Audirvana Plus (latest version) I can get PCM upsampled to 705/768, but I get dropouts and clicks at that setting. PCM upsampled to 352.8/384 works fine and sounds very good. On DSD upsampling of PCM files, I can get to DSD256 but again I get clicks and dropouts. No such problems when upsampled to DSD128. On the DX7s in Audirvana Plus upsampled to DSD128, I get strong sibilance on female vocalists, but less so on PCM 352.8/384.
Using HQPlayer/Roon on the DX7s, I can easily upsample PCM to705/768 and DSD256 (the max available on a Mac) without any dropouts or clicks, and no sibilance.
Now, in Audirvana I still can't upsample PCM beyond DSD128 without dropouts, but I can upsample PCM to 705/768 without problems. No clicks either way. And that is using tracks in mostly ALAC on my hard drive or streaming Flac via Tidal or Qobuz. No change or problems at all in using HQPlayer/Roon or Roon alone using DSD256 or PCM 705/768. HTH.
Yes I'm having no problem at all playing DSD in Roon just on it's own without HQ player.
RayDunzl
Central Scrutinizer
Riverview FL
Can someone confirm this?
I would find that highly unlikely, since it is powered via AC mains.
The complaint concerned a suspected grounding problem.
dragonspit4
Well, is it possible that the AC mains powers the amp portion, where the DAC portion is powered by USB?
I have a grounding problem with my computer for sure. In fact, I have a terrible noise problem.
Amirm said that a good DAC with proper filter should filter out all USB noise problem and ISO Regen is not needed.
Topping DX7s should filter out all noise issue since it's a good high quality DAC, why is IFI Idefender 3.0 and IFI ipower needed?
I am so confused? Do we need ISO Regen or IFI iGalvanic afterall?
RayDunzl
Central Scrutinizer
Riverview FL
Then it would require some sort of internal sensing/switching to provide power to the DAC from the internal power supply when used with the Optical, Coaxial, or AES inputs, instead of the USB.
Which makes no sense to me.
(I get to be wrong, but...)
RayDunzl
Central Scrutinizer
Riverview FL
dragonspit4
But there is no noise problem or it would show up in my tests.
During the test, you were using your lab power supply though, so of course there is no noise.
Would using a standard noisy computer power supply make a difference in test results?
Pluto
Harrow, UK
As a DX7s user, I can confirm that there isn't the slightest hint of a USB noise issue when used in conjunction with a mains-powered computer with absolutely standard earthing arrangements – no fancy isolation and a $2 certified USB2 cable!
It wouldn't surprise me in the slightest if there were an awful lot of people "out there" doing their very best to disparage this unit and many like it. I was (and remain) hugely impressed by its sound quality and I dare say that it is highly likely that there are many enthusiasts who, having spent thousands on DACs that sound no better, are a little peeved with the way the Chinese appear to be redefining the market for this kind of product.
Cynical note follows: this could be why many western high-end (i.e. high price) manufacturers are anxious to promote the MQA route – the licensing arrangements ensure a significant price differentiation in a world where the Chinese will soon be outclassing the value-for-money of western brands.
Veri
The Chinese are also jumping on MQA though, they just aren't there yet. In a year or so that also will no longer be a differentiator.
dragonspit4
Hi can you help me do a test?
Use DX7s using usb input from your computer. Start playing a song, then turn off the power of DX7s during the middle of the song and see if the song is cut off. This way we will know for sure whether DX7s DAC portion is powered by USB or by internal linear power supply.
vato3001
Germany
The Song cuts off;)
DjBobby
Swiss mountains
And time domain response to a square wave:
Filter 1
Filter 2
Filter 3:
Filter 4:
Filter 5:
Filter 6
Filter 7
Hi everybody,
A new member here, although following the forum since long.
Thanks a lot Amir for all the specs and graphs, now right to my question:
DX7s lists the filters in the following order:
Mode 1: apodizing fast roll-off filter
Mode 2: minimum phase slow roll-off filter
Mode 3: minimum phase fast roll-off filter
Mode 4: linear phase slow roll-off filter
Mode 5: linear phase fast roll-off filter
Mode 6: brick wall filter
Mode 7: corrected minimum phase fast roll-off filter
According to my understanding, the impulse responses you have published don't correlate with this order. Just looking at your graph no. 4 gives a clear picture of minimum phase slow roll-off (no pre-ringing, short post-ringing), where Topping's manual states linear phase. Further, looking at the filters 6 and 7, they seem to me clearly inverted: I would guess no. 6 to be corrected minimum phase and no. 7 to be the brick wall.
Actually your line-up corresponds perfectly with the order in the ES9038q2m data sheet on page 57: http://file2.dzsc.com/product/18/05/25/829029_170233543.pdf
My question: is it possible that Topping messed up with the names of the filters? Thanks for the clarification.
Pluto
Harrow, UK
I'd say it was exceedingly likely :eek:
FWIW I find the audible difference between the filters to be very slight with, possibly, a small preference for 4 and 5 (whatever they're called) over the others. But I must stress that the audible difference is so minimal that I'm not going to loose sleep fretting about it.
DjBobby
Swiss mountains
Thanks a lot for the heads-up. I was not much concerned with the subjective evaluation of the filters, but more with the objective data.
There is an obvious discrepancy between the Topping's filter mode numeration with associated impulse responses and Amir's measurements. Actually they only match in Filter 3, all other 6 filters are mismatched. I was just wondering if Amir could confirm his numbered filters impulse responses. If the accuracy is confirmed, which I assume it is, I would at least expect from Topping, for a unit selling for $500, to correct the filters order in their online manual.
chi2
Switzerland
Hello! New Switzerland based asr member here admiring and enjoying the knowledge and the healthy distance to audiophile ideologies in this community. A big thank you to all of you!
I would much appreciate any input on my problems with using a Shanling M0 as a transport connected to the USB in of a Topping DX7s. In theory this should work, however with my setup it does‘t. I tried two different cable combinations (USB B to A plus USB A female to USB C) but with neither I was able to establish a connection. The M0 ist set to DAC mode but the Topping doesn‘t get any signal.
What do I miss? BTW, I have no problems using a USB signal from my iPhone with the DX7s.
Thanks, Urs
