Veri
- Joined
- Feb 6, 2018
- Messages
- 9,600
- Likes
- 12,042
FYI, my A20h is on its way to Amir for testing.
Yay! Lovely
It has been a while since I used my A20H but when I had it hooked up it was on a shelf where my phone and several other cellular capable devices lived and I never had a problem. I'm *not* saying you're wrong, but I'd check the U7 or cabling first. Perhaps run the A20H off another source and see if the problem persists.My A20h picks up interference, something phone related, either internet or GSM or something like that.
It gets better if I remove my phone (or a GPS Tracker) away from the DAC/ my headphone cable.
Is this Issue related to my Xonar U7 or to the A20H?
The A20H will powerfully drive any of the headphones in your signature. I use the HE6se in mid gain and it's plenty loud with great quality.
It probably drives all (except the most demanding headphones) withe ease.
No doubt, But I think Topping L30 II has more juice...for like $50 more...
The L30 II may actually have a little more power than the A20h in true symmetrical operation, but the L30 II only has a cheap potentiometer with the usual channel deviations, which is also subject to aging.Output Power: 4W x 2 (16 Ω) 2W x 2 (32 Ω) 1W x 2 (300 Ω) 500mW x 2 (600 Ω)
Are the power ratings for balanced headphone out or unbalanced ?
I think someone just looking at power figures will not understandThe L30 II may actually have a little more power than the A20h in true symmetrical operation, but the L30 II only has a cheap potentiometer with the usual channel deviations, which is also subject to aging.
The A20h has one of the best volume controls with absolute channel equality, relay based with resistors. With other manufacturers, the surcharge for this alone is higher than the purchase price of the A20h. It also has a remote control and real balanced inputs.
The A20h has balanced and unbalanced headphone outputs, 4-pin XLR, 4.4mm Pentaconn, 6.3mm jack and adapter to 3.5mm and the power ratings are for balanced.
What use are numbers on paper to me?I think someone just looking at power figures will not understand
I was just saying these amps today have enough power for 99.9% if headphones. So people only looking at power output and nothing else are missing the point of good products.What use are numbers on paper to me?
I had compared the L30 II with the old L30, the A20h, my old Violectric V100 and the Singxer A1 and it had no advantage in terms of sound, even though I had Amirm's test in mind.
So I gave it back.
My AKG K812, my Hifiman Sundara and also the Fostex with the foil drivers don't need a lot of power, I operate them on the low gain level for all HPAs. Of course, if you want to operate a Hifiman Susvara, HE6se or similar, ok, but the performance of the L30 II may then be too tight.
I would guess around 10 ohm or higher if it was designed following the recommendations of the tpa6120a2.I know this is a A20h thread but I have a question about Sabaj PHA2, since I cannot find any info about Sabaj PHA2 anywere:
Sabaj PHA2 has a 6.5mm headphone output jack which is for high impedance headphones and a 3.5mm jack for lower impedance headphones… I have read that there are two resistors before the 3.5mm jack…
What are the output impedances for each one of the ports(3.5mm and 6.5mm) ? I can’t find anything online…
Yep, I have seen the specs that's why what I said was based on the specs of the TPA6120A2. This amp is a "old" design that seems to follow some guidelines of the TPA manual (at least by a quick look) - different from a L30 and copies that take a "bold" approach.the official spec says that this amp is suitable for 8ohm-600ohm headphones though
I thought A20D was "inspired" on A10H and this on L30, using a zobel filter at the output.Output R on the discontinued predecessor PHA1 is 150 ohm on 3.5mm output.
A20d uses the same circuit as PHA2 which is near 0 ohm out (not measured by Amir but Archimago did).
Buy one and drop ship to Amir and ask him to measure Rout from the headphone outs.
Don't know the output R for the 3.5mm TRS out but it is just a series resistor.
