Hello.
I learned here that a new farmware 1.6 was released.
But now It looks like the link is 404.
Can anyone upload it again?
Message peterwen to get the firmware.
Hello.
I never had an issue via USB on Windows 10, no matter if USB 2.0 or 3.0.
When you say that windows shuts down during playback, what exactly are you using? Spotify, Tidal, Foobar, Youtube, gaming? Or does it happen no matter what you're using?
Do you have any other sound device connected to your computer, like an onboard soundcard or any other DAC?
Are you using any software in exclusive mode, like Foobar or Tidal?
Do you use any kind of EQ software, like Sonarworks?
I'll show my setting, so you can check if they are the same.
First of all, check your XMOS driver version (Post #69):
Playback device Control Panel:
- Disable any other device but the Sabaj D5. Even HDMI connected to the monitor.
- If you have more than one device enabled, sometime Windows sets two of them as active, which can cause some problems.
* Right click on the list to check the options for show/hide Disabled and Disconnected devices.
* Right click over them to disable.
On config, make sure it's flagged as Full-range speakers
On properties, set as follows:
Spatial sound turned off
After that, your XMOS Control Panel should look like this:
Also make sure your Device Manager has no issues, no matter the device type
Let us know if windows shuts down again and please answer my questions so we can keep track over D5's problems.
Tks
I resolved my problems by not launching several audio sources (foobar/youtube) at the same time.
Can you please tell me from where did you download the 4.67 driver version? I only have version 4.47 from the sabaj site.
It must be not so. Change in Volume is re-calibrated to 90 steps instead of earlier 40 steps..volume fino a 90, significa un volume del preamplificatore più alto?
https://drive.google.com/open?id=1bAmxqtlZ5dAMgD7cF1mwIG1kIlqJS8nd
1.6 firmware can be download here and go with the upgrade tool.
Good news, cooperate with the HiFi-express, we have a promotion sale on Sabaj D5. Don't miss the time. 1st - 3rd May. Only 30 unit can be sell on US location.Only $399.
https://hifi-express.com/collection...aj-d5-audio-dac-ess9038pro-heaphone-amplifier
