Schiit Magni Heretic Headphone Amp Review
Rate this headphone amplifier:
    Votes: 2 0.7%
    Votes: 0 0.0%
    Votes: 49 18.3%
    Votes: 217 81.0%
threni
/dev/null
I read somewhere that the USB-C connectors are very finicky. Keep in mind that USB-C is just the form factor and there are a bunch of different standards jammed into that unified port connector. It's probably possible to implement with some time, but I don't think it's worth the effort for most smaller/mid-sized companies to spend that time on it when they could be improving more substantial aspects of their products.
You just plug them in and that's it - no problem. It's a well defined standard and you can put a lot of power through it - that's what the PD standard is which the OP was talking about (although it won't work on this amp as it requires AC). You can connect a 4k monitor to a laptop and power the laptop from the monitor via USB-C. It's great. A lot of connectors support different standards - you can plug two devices into a monitor via HDMI, for example, and discover one of them only updates at 30hz in 4k mode - nice. Standardizing on USB-C at least allows for consolidation of all these other sockets into just USB-C allowing cable reuse and ideally one standard to bind them, although I'm sure cheapskate manufacturers will screw that up as usual by cutting corners to save costs, be first to market etc.
BadAudioAdvice
CAN / USA
@amirm Would it be possible to also test the the pass-through RCA connection to ensure that it doesn't degrade the signal?
Or is it also possible that having an amplifier connected to the output RCA would affect the performance in some way?
charleski
Manchester UK
is anyone interested in seeing the NITSCH x Schiit Magni Piety measured here?
For amusement value maybe ...
The blurb on the product page certainly doesn't inspire confidence: "Solid state practicality, tube-like sound", "Measurements aren’t the whole story". We all know this is just code for 'this is a product for those who like to pretend they enjoy distortion'.
Veri
Atomicbob on SBAF did a measurement suite and it did seem to have good linearity etc. I mean besides the scatchy small-part volume pot on all these magnis I'm sure they're all fine in use as long as you're not driving a HE-6 or Susvara..
DonR
Vancouver(ish)
Seems to be DC-coupled so users need to keep an eye on DC offset (or risk damaging their headphones as was the case with some older Schiit amplifiers iirc).
@amirm Something to consider adding to your measurement suite.
I see a relay on the headphone output. Would be nice if they had a DC detection circuit to cut the output as power amplifiers have. More than likely the headphones connected to this will be more expensive than the amp itself.
Badunn
Better job of socket alignment on the back compared to the modi+
These designs, with no bells and whistles, just the simplest audio path, are now realising the straight wire with gain objective. When are the ‘hi end’ manufacturers going to realise they are no longer, or ever have been, hi end? Or do we put it down to ignorance? Feel like I’ve been robbed all those years. Been fun though :D
T.M.Noble
There is overcurrent and DC protection on both Magni+ and Heretic. Your headphones will be plenty safe.
Billy Budapest
JDS Atom+ (same SINAD and price)
Advantage: Atom has two inputs: RCA and 3.5.
Disadvantage 1: The case is plastic and the contents so flimsy that there are fill-weights in the case. The adhesive on one weights gave way for me so I had to open it up and remove it. Now it is even more lightweight. The form of the Heretic is surely better.
Disadvatage 2: The Heritic has more power.
You can ask JDS to build it with heavier weights (or more weights) if necessary.
solderdude
The Neitherlands
The Heretic indeed has DC output protection .... YEAH no more blown (expensive) low impedance headphones when it happens to fail.
And also important... the headphone output connector on the left and not close to the volume control
Gain options also very practical -8dB, 0dB and +14dB ! Progress.. the little amp that could !
Doodski
Well done Schiit! I will be recommending this model. Very nice. :D Any chance Schiit can offer a ~6" RCA cable with memory for bending for connecting a DAC to the headphone amp. Then we don't need to suggest going to JDS Labs to buy one. One stop shopping is where it's @.
beren777
I think Audioquest has a cable for the 3pm hour...
Not to go too far off topic but this would be an amazing marketing gimmick.
"Your body's circadian rhythms change throughout the day, why doesn't your audio system change with it? Thanks to advances in chronobiology and precision blending of octagonal (like a fine Piguet watchface) metallic crystals, our new Circadagold cables come with an adjustable circular band you can rotate to match your current biological time for peak performance! Just keep rotating until everything from the crystal highs to the thunderous lows ring true!"
I'll be right over here filing a trademark...
pseudoid
Thank you Amirm,
Have there been m/any other hardware that have polled zero votes for "1.Poor (headless panther)" ?
