Singxer SA-1 Review (Balanced Headphone Amp)
raif71
When this amp was only 1 day old at my house, I was unhappy because I could see a lot of dirt through the gap of the case.
I worry because I enjoy listening to the amp especially after setting it to high gain. I'm using it with Senn 6xx series, hd800 and Sundara :)
Roland68
Cologne, Germany
Dust can come in through the side openings of the amp. Also, I'm worried that ants, spiders or other bugs go inside via the side slits and make a home in the amp :eek:
But that could be "exciting" for the animals ... :D
Perhaps you can tell by the "grill smell" which animal it was.
Roland68
Cologne, Germany
Does anyone know how much K the potentiometer has in the SA-1?
Rantenti
Do we have any numbers on the crosstalk of the Singxer SA-1? Curious to know if its imaging accuracy and separation surpass Topping A90, which published their crosstalk figures.
khark
The Old World
Roland68
Cologne, Germany
Is the chart for Balanced or SE?
Perhaps the question is too vague.
Which input and which output on the SA-1 was used?
nnitr
Does anyone know if it is fine to only use the on/off switch on the back and not the one in the front? Thanks in advance.
Celty
My understanding is that the front toggle switch has positions that set the amp to headphones, preamp out, or standby "Off" mode. The rear rocker switch, is a true On/Off switch. I don't think there is any reason to not use either front or rear switches.
Billy Budapest
First, apologies for sounding snarky, you don't necessarily know. Now quote: "But the USA makes almost no consumer electronic parts", WAS the context, you also said: If this was USA, it would means that it containt PARTS that are from abroad.
Just pointing out that USA is, by a good margin the largest semiconductors components manufacturer in the world. Sure, no debate that for everything else, assembly, mechanical parts, Plastic molding, etc, etc, etc, Asia is far far ahead, but it is not the point you first made!
It’s funny, a crapload of plastic molding is done in the U.S.—compression press molding, injection molding, blow molding, etc. It is a huge industry.
tom.chen
yes,you are right.
bequietjk
Slightly off topic but seeing that the channel imbalance isn't exactly a straight line, for music production how much of an issue would this be and is there a way to balance the channels via software?
Roland68
Cologne, Germany
The software doesn't know what position the volume knob is in. Channel inequality fluctuates along the way, but it is especially strong at the beginning and at the end.
You could swap the potentiometer for one with SMD resistors.
NPWS
Hi,
I have D90SE pairing with Singxer SA-1, I've tried several times to listen between Line out Type : RCA out only, XLR only and RCA+XLR using USB from my PC using foobar, turnout that RCA only have bigger power, more clear and everything than XLR only or RCA+XLR, using XLR it should have more power yes?
XLR only was the same with RCA+XLR, to my ear.
RCA only was bigger power than all of them : XLR only or RCA+XLR.
I know RCA only on d90se = 2.5V
XLR Only = 5V
RCA on RCA+XLR = 2V
XLR on RCA+XLR = 4V
from what I heard on my SA-1, RCA out only have more power than XLR only, for example I drive my hifiman he400i using RCA only I set the volume on my SA-1 between 10 / 11 o'clock, but when I switch to XLR only I have to adjust the volume to 1 / 2 o'clock to get the same amount of volume match as RCA out.
I always set my SA-1 on low gain, when I switch to high gain, its still the same, RCA out only was always have bigger power.
I'm afraid that my unit was defective. is my D90SE defective or my singxer sa-1? I dont have any other dac and amp to test with.
Thanks
Veri
Hi,
XLR Only = 5V
RCA on RCA+XLR = 2V
XLR on RCA+XLR = 4V
Thanks
I think it's the SA-1 and not the D90SE in any case.
I would assume the converter circuit is making the 2.5V input go stronger than just a doubling of voltage, resulting in more volume than using the D90SE balanced XLR output..
Eldgrim
Hi,
XLR Only = 5V
RCA on RCA+XLR = 2V
XLR on RCA+XLR = 4V
Thanks
If I recall correctly, the way SA-1 is designed makes the output volume the same whether you use RCA or XLR input when XLR input is double the voltage of RCA input, due to the gain on RCA being higher than XLR.
Roland68
Cologne, Germany
Hi,
I don't understand exactly what you connected and how.
What do you mean by "and RCA + XLR using USB from my PC"?
Or with "XLR only was the same with RCA + XLR, to my ear.
RCA only was bigger power than all of them: XLR only or RCA + XLR. "
What was connected, how and to which device?
Veri
D90SE has settings, XLR only, RCA only, RCA + XLR. Output.
NPWS
is it caused by the SA-1 input impedance being too low?
so my unit was normal?
like @Veri said D90SE has settings, XLR only, RCA only, RCA + XLR. Output.
