Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
Correct!No dropouts, no problems ?
I just bought SMSL D6, and was running it through usb from my laptop and I have the same clicking popping noises while playing Tidal or Foobar on Windows 10. I dissabled the Power managment of the USB ports in Control Panel and no success. These clicking noises occur randomly during the playback of the tracks (not between the tracks or changing the sample rate). I tried what @pjoh suggested in this thread, to activate Streaming Always On in the Control Panel of the XMOS driver, but that didn't change anything. Does anyone have the same problem and have some instructions about this problem?
can someone please tell me the opamp used on this dac? thanks
I searched for the word opamp in that thread and no results foundThoughts on SMSL D-6 DAC?
It's been out since June it seems, so hopefully early batch issues (if any - I don't know) are sorted by now. I might wait 1 more month to orderwww.audiosciencereview.com
No words, there should be this video (in vietnamese I guess)I searched for the word opamp in that thread and no results found
based on pics i found on line, smsl uses opa1611 and 1612 in the da-s8 and m400, so there's a possibility that's what's used here. but are you really wanting to replace smd opamps?can someone please tell me the opamp used on this dac? thanks
OP amp rolling with IC's is for absolute beginners.
Real men have discrete OP amps, even mounting will be a challenge
Supreme Sound Opamp V6 - Burson Audio
The Burson V6 is a Class-A discrete opamp, epitomizing Burson Audio's engineering excellence. Offering unmatched clarity and detail, it's a top choice for audiophiles upgrading their equipment.www.bursonaudio.com
Not really they're just a bit tall. Also for the record Burson (used to) send these around on head-fi if you're active for an "honest" review as in they publish whatever sweet syrup you conjure getting a free tall discrete OP amp gift reminds me of those scam 5-star amazon products.OP amp rolling with IC's is for absolute beginners.
So you are aimung for suchNot really they're just a bit tall.
never said I was going to change the opamp. just more like wanting to know. like on the do100, SMSL clearly mentions it's using OPA1612x4. I'm guessing the ones on the D-6 are not special?
It'll be similar. Seems to be some TI SoundPlus™ OPA1611/OPA1612. As are most very low distortion output stages nowadays, actually.never said I was going to change the opamp. just more like wanting to know. like on the do100, SMSL clearly mentions it's using OPA1612x4. I'm guessing the ones on the D-6 are not special?
We've just kidding. Nobody thought you really want to do this, because with tweaking you could only make it worse and not better.never said I was going to change the opamp.
maybe if you query smsl, they will tell you. or someone can open one up and look...never said I was going to change the opamp. just more like wanting to know. like on the do100, SMSL clearly mentions it's using OPA1612x4. I'm guessing the ones on the D-6 are not special?
