SMSL D-6 DAC Review
Rate this DAC:
    Votes: 4 1.4%
    Votes: 10 3.4%
  • 3. Fine (happy panther
    Votes: 90 30.8%
    Votes: 188 64.4%
Palladium
There is this too. Quite a value. Was just on sale for $55. You could do worse for 5k VS this $55.
Side rant: If only the SPDIF/Coax on the D10 variants were inputs; certainly much more useful IMO that way.
Jimster480
Tampa Bay
When will the current firmware be updated?
The clicking issue is a problem that occurs across users of D-6. I assume that you received the report about this problem before, but there is no notification about when it will be updated.
Tell us your plan, please.
That is not the manufacturer. Smsl is the manufacturer
Kevinfc
Bought it. My only gripe is that the remote is pretty useless. You’ve got to be close (less than 10 feet) and right on level. I picked one up for $59, so even without the remote it’s a nice deal.
irontortoise
Texas
Super happy with the SMSL A12. I had been looking at the D-6, and Amir's review sealed the deal for me. I ordered it. Fingers crossed they release firmware to fix the clicks.
Laserjock
Texas Coastal
This is a review and detailed measurements of the SMSL D-6 balanced stereo DAC with Bluetooth. It was sent to be by Shenzhenaudio and costs US $169.99.
I like the compact enclosure even though there is a built-in power supply and balanced outputs. Included volume control lets you bypass a pre-amp and driver a power amplifier directly.
SMSL is joining others in using compact TRS for balanced output. Along those lines, USB input is also the diminutive USB-C connector.
I found the navigation of settings or even changing inputs to be somewhat confusing. This is compounded with selections not rolling back to the beginning. So you wind up pressing buttons while seemingly nothing happens because you are at the end of list of selections.
AKM AK4493 DAC chip powers the unit.
SMSL D-6 Measurements
Let's start with RCA output:
Distortion is well below threshold of audibility so noise sets SINAD. Switching to balanced output improves the situation still:
For a budget DAC, this is excellent response, ranking above average in that category alone: (highlighted in yello)
Dynamic range is situated the same:
Multitone test shows off the low distortion:
Linearity is excellent to 20 bits limit of measurement:
Great to see jitter being extremely low for all three inputs and not just USB:
IMD test shows off the low distortion:
We have the usual filter settings from AKM:
None are sadly very sharp so we see the effect in THD+N vs frequency which uses a wideband measurement spectrum of 90 kHz:
We can see why if we perform an FFT:
Fortunately not an audible artifact.
SMSL delivers an excellently engineered DAC with my favorite features of included power supply and balanced output at very budget friendly price. You don't get state of the art performance but come close while saving fair bit of money. The D-6 is also stylish with its compact and slim size.
I am happy to add SMSL D-6 to my recommended list.
Did you check it like the M500 Mk 2?
“ I did test for one channel being active which was an issue with the original M500 and the bug is not here so all is good”
carlcamper
Cavite, Philippines
Oh, I'm sorry. I didn't know it.
By the way, do you have any idea when the firmware will be updated?
As per SMSL it is Shenzhenaudio who is in charge of support, as they are the official partner for this DAC. Ive been in contact with them, but they cant seem to replicate the issue. Maybe if more of us report, it will expedite a fix.
WhyNotHad
Yeah so I've already reported this issue to them.
I don't want to replace the product, but want to fix the clicking issue through firmware update.
While Topping's update is fast, SMSL's update process is slower than I thought, so I was disappointed about this recently.
carlcamper
Cavite, Philippines
Agreed, if I didn't the workaround of having a Topping D10 Balanced with USB in to Optical Toslink out feeding into the D-6, I would be pissed.
carlcamper
Cavite, Philippines
Bleib
Sweden
Subjective review, according to Randy the S in the DAC's name stands for sibilant
Bleib
Sweden
Review sucks tbh
Don't know where he gets the sibilant from, likely I wouldn't agree but it can be fun to listen to the review anyhow. He's certainly not right about the price of this DAC.. usually balanced output drastically increases the cost.
WhyNotHad
-Good measurements
-Bluetooth function
-RCA Unbalanced out
-TRS Balanced out
-Preamp mode
Just satisfaction
and there was no problem with linearity. If I point out the problem in it, it can be the click issue and the absence of the ground due to the -/+-only power supply.
I wonder where he felt the sharpness through this dac, his clip is interesting tho
Jimster480
Tampa Bay
-Good measurements
-Bluetooth function
-RCA Unbalanced out
-TRS Balanced out
-Preamp mode
Just satisfaction
Not sure, what clip are you referring to? I don't like his whole video, but i Guess its a format for people who don't like to read.... most of the video is him just going over the actual products specs...
WhyNotHad
"I think"
What I'm talking about is what I felt in it
D-6 is good
manudrz
Hi, I've received mine today from Audiophonics. 5 minutes on to check if it's ok and then unscrew :p
The 4700µF are 1 mm above the 2 DACs, I don't think this is in the datasheet...
Can't really test and listen to it now, I'm on a DIY active system and it will need tweaks to plug it together. The SMSL will feed a 3e audio TPA3251 through TRS.
