SuicideSquid
- Joined
- Jan 20, 2022
- Messages
- 702
- Likes
- 1,657
Please show where I have mentioned that I assume that I have.
So where is Benchmark's ABX testing system lacking in scientific rigour ?
Why does Amir measure measure out of band noise in amplifier power supplies ?.
Rather than constantly attacking me show some measured science to support your absolute objectivism. Surely the proven science has simple answers to my often asked questions.
You claimed to be able to perceive a 2dB difference in SINAD between two dacs that both measure effectively perfect across the audible spectrum. This is extremely unlikely.
There is nothing wrong with Benchmark's description of their ABX system. The problem is in your interpretation of their methods and measurements. A problem with how some DACs reconstruct a waveform could not possibly explain a perceived difference between two amplifiers, neither of which are converting digital to analog. Further, Benchmark repeatedly emphasizes the need for level-matching and blind testing in order to ensure you're perceiving actual differences between devices, and not merely experiencing expectation bias. This is what we've been talking about the entire time. If you're just switching back and forth between two devices without care to blind yourself as to which device you're listening to, and without care to ensure that both devices are outputting the same signal level, you're going to fool yourself - either by simply preferring the louder device, or by thinking you're hearing differences that aren't there.
I cannot speak for Amir, but I understand that out-of-band noise is often measured for several reasons - too much ultra high frequency noise can suggest mistakes in design that may manifest in other areas as well, may adversely affect the efficiency of a system (if you're pumping inaudible noise through a system, you're still having to expend energy amplifying that noise, which is not good), and in some rare cases UHF noise can cause artifacts in the audible spectrum; however, in all of these cases, this is a measurable phenomenon, and in no case would I expect the difference between ultrasonic noise between the Benchmark and Hypex amplifiers to make a measurable difference, because across the board the amount of noise is miniscule.
The simple fact of the matter is that the measuring devices Amir and others use to test DACs and amplifiers are far more sensitive than the human ear, and if you think you're detecting either unmeasurably tiny differences between devices, or measurable differences that are generally considered to be below the threshold of human hearing, you're probably fooling yourself, and the only way to be sure that you're not is to do a proper double-blind test.
I am also not sure you understand what objectivist means. If two devices measure differently and you prefer the one that measures worse, awesome, more power to you. You're not wrong. Listening is ultimately the final arbiter of what sounds good to you. But you have to be listening in a way that ensures you're not fooling yourself. Everyone - me, you, the writers for WhatHiFi and Stereophile - are easy to fool, because we're human beings, and we have limitations. You must take those limitations into account when designing listening tests to try and detect tiny variations in electronics, or else you're going to hear differences that aren't there, and end up dying on a ridiculous hill like 'I can hear the difference between 121 SINAD and 123 SINAD" or "ultrasonic noise measuring below -120dB makes a difference in the audible spectrum".
