Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
lol. BenderDACI can't remember if I have posted this already, but SMSL is preparing a bended version of the SMSL SU8.
yeah u posted this alreadyI can't remember if I have posted this already, but SMSL is preparing a bended version of the SMSL SU8.
NAD 326 bee does not have an XLR input. So connect with RCA. There is no problem with the signal level.Would you guys recommend to connect this little Bender Boy via XLR or RCA to a NAD 326 bee ?
Would be there any tissue with the 4V Output via XLR by overmodulation/overdrive ?
There are multiple physical mods available (SDR comes to mind), but I use Equalizer APO w/ Peace plugin. Adjusted based on https://www.reddit.com/r/headphones/comments/9o2f5n and still playing around with it.How do you EQ'd? Is it electronic process or physical one?
Ha, I have done the same thing, different headphones, but same outcome - it is easy to get lost with music that is so involving.SU-8 V2 + Monolith 887 + HD800 (EQ'd) = Fantastic!
The EQ is necessary cause of the HD800 but I've listened for 4 hrs+ each in the first two nights without realizing it. My wife had to drag me at 2AM each night so I wouldn't miss work the next day.
Again we are doing the same thing with Equalizer APO w/ Peace, I look for EQ settings that were based on measurements for the same model headphone, adjust from there if my ears tell me to, but generally they seem to be spot on..There are multiple physical mods available (SDR comes to mind), but I use Equalizer APO w/ Peace plugin. Adjusted based on https://www.reddit.com/r/headphones/comments/9o2f5n and still playing around with it.
Still waiting...... no infoIn case you missed this from Liu at SMSL when asked about the new SMSL SU-8 revision (the SMSL SU-8S):
At the risk of stating the obvious, did you check the batteries?I recently purchased a SU-8 DAC . I am having difficulty in getting the remote to work. Having read the manual, I have pressed button 'C', but the remote still doesn't function. Any ideas? Ta
