SMSL SU-9 Balanced DAC Review
ninetylol
Really? I feel like I might need the additional 8db of SINAD and integrated BT 5.0
Does ASR have a classifieds? Maybe someone needs this thing for $200.
You can get a new su8 for 200 though :p
ReaderZ
I remember my old pc audiocard EMU 1212M, it used to click when changing sample rates. I always loved that click, it seemed like smth inside the card was changing. It sounded better with that click.
I had that card too, I think you have to use different "strips" too?
Dougey_Jones
Dougey_Jones
gvl
SoCal
It’s totally ok to keep SU-8 v2 and not sell it for SU-9
Not sure, thanks to the placebo effect I find the "Pro" ESS based DACs to easier to listen to than the mobile ones.
makatech
Hmm, what's the main/major differences between su-8 and su-9?
Bluetooth and MQA support while the DAC chip is the same?
The difference in price between Topping D90 MQA and SMSL SU-9 is more interesting and surprisingly big right now I would say ($360...). The Topping D90 MQA has to be really good for justifying this difference. Comparing to SMSL SU-8 obviously even bigger difference but not a fair comparison because SU-8 missing in features comparing to both D90 MQA and SU-9.
I am fully aware of D90 is having another DAC chip though, I have no idea if this is better or preferable than the one SMSL SU-9 (and SU-8?) is using though, probably a matter of taste with subtle/minor differences?
ninetylol
Smsl su-9 uses another Chip (the Pro one). Also MQA for those who want it. But Yeah value is better on the 8
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
None that would be audible.
Dougey_Jones
Are there any substantive differences between the Sabre chipset in the SU-8 v2 and the “Pro” chipset in the SU-9?
Veri
Possibility of cleaner SINAD/distortion specs if implemented well (as is the case here). The case on audibility would say they probably sound the exact same. But on paper the 9038Pro will win if you want the "best".. :)
gvl
SoCal
Not that we saw in measurements, the Pro based DACs tend to have lower THD at higher frequencies, but the differences should be inaudible.
Dougey_Jones
Since we’re already discussing these ESS based DACs, can anyone comment on the 7 “preset” filters that you can select from on these units? Is there one preset that’s considered “reference” or baseline that should be selected?
gvl
SoCal
I wasn't joking when I mentioned that I prefer the sound from the Pro based DACs over the mobile version, but at the same time they sound pretty much the same even in sighted AB switching, so it's likely the placebo effect in action but having gone through, 3 9038 mobile chip DACs and 2 Pro ones, the overall mental impression I'm left with the mobile ones they sound a bit less refined.
gvl
SoCal
I tried many times and can't discern any differences between them. I can't hear above 15kHz, that's likely why. I set it to Fast Linear and forget, technically it's the correct filter to use.
Dougey_Jones
I’ll check that out, thank you!
KNUPAC
should i get this over topping d90 knowing that i already owned topping d70? will i get a significant audible upgrade?
Dougey_Jones
Can someone address this Reddit post on this subject.. is this guy right? I’m not an EE and honestly don’t know. This person claims anything besides brick wall is wrong wrong wrong.
