TAD Evolution 2 Speaker Review
Rate this speaker:
    Votes: 66 15.1%
    Votes: 208 47.5%
  • 3. Fine (happy panther
    Votes: 150 34.2%
    Votes: 14 3.2%
VintageFlanker
Paris
Sounds from Amir’s description that it looks and feels very high quality in real life, but I was just thinking exactly what you said.
Yep. I have no doubt that build quality is excellent (how could it be otherwise for 20k speakers made in Japan?), but it looks like... nothing.
And I'm saying this while TAD makes ones of my favourite looking speakers ever:
jhaider
I was disappointed (in the academic sense at least - I wasn’t a potential buyer) that TAD was abandoning their “CST” coax in this new model at least. They had at least 4 versions of CST, with the same basic geometry: an all-Be one with the expensive vapor deposited mid cone, one or two versions with 7” (called 6”) magnesium cone and Be tweeter (Pioneer S-1/2/7EX, TAD Evo 1), a 6” (called 5”) version with magnesium cone and ceramic-graphite tweeter (Pioneer S-3/4/8EX, S-iw6/7/891 in walls, S-ic6/891a in ceilings), and the baby one for ME-1. I guess a TAD badged version needs Be but it’s hard not to see going from a 3 way with sophisticated coax to a 2.5 way with basic waveguide as cost cutting inappropriate to the price point. Especially when measurements aren’t better than one finds from most peer brand and some much less expensive speakers.
CST in its ~15 year old form may be a little long in the tooth compared to current Genelec or KEF coaxes, but it’s only real problem is an on axis cancellation notch that quickly fills in. There’s some sophisticated cone damping and tweeter geometry that leads to really fine performance.
Purité Audio
Industry Insider
Barrowmaster
London
Compact reference 1 from Stereophile,
Evolution 1 Stereophile
Even the Micro Evolution ( not Andrew Jones) isn’t bad ,
Sancus
Mnyb
Sweden, Västerås
Hmm no reason to buy TAD if they ditched their famous coaxial driver. Thats was the whole charm with their offering? (When i win the lottery )
3125b
Germany
Why not make this a 3-way - that would have helped to avoid at least some of the issues, and at 20000$ there is no need to save money on the crossover ...
fredoamigo
South East France
What should I tell him?
20000$ is like 22000 € now dude
Except that the price in Europe includes the 20% tax (VAT) rarely in the USA...... look for the error
delta76
yes. which means the price in US is even more expensive than EU. By EU laws shop must display prices inc. taxes to individual customers
thewas
The on-axis/LW peak at 600 Hz and presence dip are disappointing at that price point as the directivity is well behaved and those could be corrected with a better crossover tuning, same as the vertical lobes at the crossover region, especially the one close to listening spot at -10°:
Here is the vertical:
TAD Evolution Two Tower Speaker Vertical Directivity Response Measurements.png
Maiky76
French, living in China
This is a review and detailed measurements of the TAD Evolution 2 tower 2.5 way speaker. It was sent to me by the company and costs US $20,000.
Sorry for the cellphone shot of the speaker on Klippel NFS. I have not had the time to test it in the house.
The fit and finish is impeccable. The binding posts is likely representative of the quality inside:
It is full custom with a level of precision that makes it a pleasure to tighten the screw on the terminal. The fit is so perfect against the threads that make you feel there is fluid/oil in the thread but there is not! An example of very high precision machining.
Reference axis for the measurement was the center of the tweeter. No grill was used. Measurement axis is parallel to ground plan. 1500 measurements were performed in 3-D space (50% higher than my normal standard) generating 1.2 gigabytes of data.
I have shared my results with the company representative. Alas, I have not heard anything back despite checking a couple of times.
Here are the company specs:
TAD Evolution 2 Speaker Measurements
As usual we start with our CEA-2034 frequency response measurements:
Great to have good bass extension. Alas, the rest of the response is somewhat variable which is likely due to interference from multiple sound sources. Here is the near-field response:
Nice to see port/cabinet resonances being suppressed well. Company specs the first crossover point at 90 Hz. I am not seeing that effect so perhaps the near-field measurements are polluted by the other woofer?
Anyway, here is our early window reflections:
Nothing to add other than the comment on the graph. Here is our predicted in-room response:
Horizontal directivity is good so we should have good luck with EQ:
Benefit of 2.5-way design kicks in lower distortion, at least at 86 dBSPL:
At 4.5 ohm minimum, lowest impedance point is slightly better than average which is appreciated:
Here is our waterfall and step responses:
As I noted, due to lack of time, I do not have listening impressions for you.
I guess I can state the obvious that given TAD's stellar reputation in speaker designs, I walked in expecting perfection. We did not get that. I let you all vote with what you think of the measured performance. I am delighted about the quality of the speaker though.
I should also mention the incredible support and generosity of the company to work with me and send me these samples for testing. No other company has offered such expensive speakers for testing.
I can't see the usual data in the file that is attached
Mnyb
Sweden, Västerås
This is usually an economic compromise you get the surface area of two drivers in the bass for higher output capabillity.
But I agree this kind of compromise is for much cheaper speakers, for this money one should expect an optimized midrange driver and a larger bass driver or a dual bass drivers as it is now but with a dedicated midrange
Arc Acoustics
Japan
TAD Evolution Two Tower Speaker Horizontal Beamwidth Response Measurements.zip
580.4 KB
The file you attached contained 11 image files but no text file.
Is there no raw measured data at this time?
okok
TAD is one bitchy pricey brand, this is only their entry stuff, they got this silver midrange, the color is silver, sandwich materials
edit: should be ATD
Reactions: buz
