Probably meant to be used with a tube amplifier that has significant roll-off on highs as well?Probably meant to be used near or even on a wall, that adds bass support.
Yeah, although (FWIW) in my experience with the Dynaco loudspeakers (i.e., SEAS woofers, in most cases, and if memory serves*): 1) the surrounds more than occasionally will suffer partial detachment from cone and/or frame (reparable, of course, but careful alignment is required) and 2) VC dragging is fairly common, too.I'll be getting a pair of Dynaco A25's in for testing this weekend. The owner wants me to replace the crossover components (a cap and some resistors). I won't be able to send one to Amir, but I will take lots of measurements. As I recall, the woofer had a big rubber surround and usually doesn't need repair.
That's the larger varient of the A25--the A50? It looks like the same drivers in a bigger box. The woofers on the two I just got in are in great shape. I've listened and compared, and have taken a lot of measurements--I'll post later today.Yeah, although (FWIW) in my experience with the Dynaco loudspeakers (i.e., SEAS woofers, in most cases, and if memory serves*): 1) the surrounds more than occasionally will suffer partial detachment from cone and/or frame (reparable, of course, but careful alignment is required) and 2) VC dragging is fairly common, too.
DSC_9644 by Mark Hardy, on Flickr
_____________
* maybe ScanSpeak -- or maybe ScanSpeak, too? I forget & I am too lazy to check today.
Right you are.IIRC, the A50 had two 10”. I’m thinking A35.
Heh, tracked it down.Yes. They did this on the production line for each speaker, according to Dynaco literature of the time (which I have unfortunately long since lost.)
Box tuning peaks are indeed present on every box speaker but there is a difference- to an amp- between an 8x peak and a 2x peak. Is it that farfetched to suppose that that might make a difference, especially to a load-sensitive 30WPC transformer-coupled tube amp?
It's a 1971 Dynaco catalog scan. You can just download the catalog via the link at the bottom of that page. Free registration required to download hifiengine's content -- and well worth the effort (IMO). Lots of good and useful stuff there, old and new.mhardy6647 you are my hero... I have been searching for that for years. I don't see that page in the linked material though- which doc was it in?
Not an 'urban legend' after all, eh? Maybe that's why it still gives a decent account of itself > 50 years after its introduction- and why you can't reproduce the results using homebrew, 'seat-of-the-pants' methods....
Interesting that those who have expressed an opinion here seem to prefer the 25, considering that the Advent sold for quite a bit more during their parallel lifespans.
Interesting stuff.
Yes, A-35 was a slightly larger version with a sealed two-camber cab, the divider containing the port.
A50 had two 16Ω woofers paralleled.
It occurs that a couple A25s, for the right price, might make a good low-buck system with a 'budget' modern sub. IIRC I saw the 'A26' for, what, $2500 a pair?!? Not competitive at that price. A 'cheap & cheerful' eBay or thrift shop find, OK...
Advent's literature discussed the driver size/cab size choices. The basket they used was big enough for a 12" cone but they made a 9" custom cone. Definitely went deeper than the A25, but with the right sub.
I opened my A25s back in the day and coated the baskets with plasticlay as suggested by Frank van Alstine. Opening them was intimidating but not that difficult, I can understand why Dennis might be reluctant to open speakers that aren't his, but it's the only way to access the crossover cap. Speaking of diffraction, a thin layer of plasticlay on the front panel might alleviate that a bit. I'd be careful not to let any on the grill cloth though- you'd never get it off (or run the speakers without grilles).
Thanks to Dennis for the data. One question, the phase plot for the A25 looks more uniform or does that have someting to do with the graph?
I don't have the technical background to evaluate this, but it would be great if someone with expertise in woofer design could chime in. I did manage to get the woofer out and test its free air parameters. The Fs is 31 Hz, or about 10 Hz higher than the Advent woofer. The Qts is .93, so this is definitely a true acoustic suspension woofer. They don't make them like that anymore.
Is it possible to post all the TS parameters you measured. Did you do a mass added test to get VAS etc......?? Someone earlier put a nice link to a speaker kit by SEAS. As I understand it, this is supposed to be a modern copy of the A-25. The spec's of the SEAS woofer used are quite a bit different then your measurement. The QTS is ".39 " ........FS is 25hz. The EBP product on the woofer you measured is quite a bit lower then the current SEAS woofer being used in the re-make. So they both fit a sealed box profile but your woofer fits better. I wonder if the motor system on your woofer has lost some energy over time.? However High 'Q"'s were the order of the day in many woofers designed during that time period. Sealed box design was more popular back then also. I'm trying to remember when exactly TS data came on scene?? I don't know the MFG. date of the A25's from xxx date to yyy date?? So while we now routinely look at TS data, during the time period I'm not sure engineers did? As I remember in the 1970's TS data in design was very very new. The companies Koss and Electro-Voice were some of the 1st companies that advertised TS engineering in their designs. I point this all out because if you didn't have TS data available you were designing speakers in a different way. If it's helpful I will post full TS data on the current SEAS woofer used in this kit. ANYWAY THANK YOU DENNIS FOR ALL YOUR WORK!I don't have the technical background to evaluate this, but it would be great if someone with expertise in woofer design could chime in. I did manage to get the woofer out and test its free air parameters. The Fs is 31 Hz, or about 10 Hz higher than the Advent woofer. The Qts is .93, so this is definitely a true acoustic suspension woofer. They don't make them like that anymore.
I didn't do a mass added measurement for Vas, but I will tomorrow. I've worked with the modern Seas"replacement" woofer, and while it does work sealed, it's not an acoustic suspension design. The mechanical suspension isn't compliant enough for that. I'm not aware of any major woofer manufacturer that is marketing acoustic suspension designs today. Although the woofers in my A25's look to be in excellent operating condition, the electrolytic tweeter cap has drifted out of spec. It's supposed to be 5.0 uF, but measures 6.2 uF. I'll be replacing that with a poly cap.Is it possible to post all the TS parameters you measured. Did you do a mass added test to get VAS etc......?? Someone earlier put a nice link to a speaker kit by SEAS. As I understand it, this is supposed to be a modern copy of the A-25. The spec's of the SEAS woofer used are quite a bit different then your measurement. The QTS is ".39 " ........FS is 25hz. The EBP product on the woofer you measured is quite a bit lower then the current SEAS woofer being used in the re-make. So they both fit a sealed box profile but your woofer fits better. I wonder if the motor system on your woofer has lost some energy over time.? However High 'Q"'s were the order of the day in many woofers designed during that time period. Sealed box design was more popular back then also. I'm trying to remember when exactly TS data came on scene?? I don't know the MFG. date of the A25's from xxx date to yyy date?? So while we now routinely look at TS data, during the time period I'm not sure engineers did? As I remember in the 1970's TS data in design was very very new. The companies Koss and Electro-Voice were some of the 1st companies that advertised TS engineering in their designs. I point this all out because if you didn't have TS data available you were designing speakers in a different way. If it's helpful I will post full TS data on the current SEAS woofer used in this kit. ANYWAY THANK YOU DENNIS FOR ALL YOUR WORK!
As an aside, from a 1999 published interview (Vacuum Tube Valley, No. 15) with David Hafler:Related to the Dynaco company test spelled out in their advertising literature quoted above. Of course David Hafler was one of the principals behind Dynaco. He was also an amplifier designer. So he clearly must have seen some value it the test as spelled out related to load...
I think you mean that Advent sold more of them. They were certainly not more expensive in real dollars (remember the high inflation of the period--even a couple of years change prices significantly)....Interesting that those who have expressed an opinion here seem to prefer the 25, considering that the Advent sold for quite a bit more during their parallel lifespans.
I don't know if that is or isn't the case, but this seems like a propitious time to mention*... umm... the "new" KLH 5, which claims to employ acoustic suspension for its woofer alignment.The Fs is 31 Hz, or about 10 Hz higher than the Advent woofer. The Qts is .93, so this is definitely a true acoustic suspension woofer. They don't make them like that anymore.
