Time Domain measurements?
haraldo
West Norway
We use Dr. Brüggemanns UB Filters. They are a further development of the Horbach-Keele. They are steep but the result is optimal time domain behavior nevertheless.
Thx :cool:
I can't however find any wiritings on Dr. Brüggemanns UB Filters, do you have any pointers, links or info? :)
UliBru
Thx :cool:
The UB filters are based on the idea that kinks or non-smooth transitions in the frequency response cause some ringing in the time domain. Thus the target is to get smooth frequency responses. An indication is the behavior of derivatives, like kink (1st derivative) or jerk (2nd derivative). A curve without jerk requires at least a polynomial of 5th order. The UB filters are now given up to 11th polynomial order = smoothness up to 5th derivation.
An example of first order UB jPol11 with corner frequencies 300 Hz and 2 kHz:
As you can see the filters are quite steep. They add perfectly.
The linearphase step response:
I hope this answers your question.
haraldo
West Norway
Thx a lot for your quick response :)
I don't understand, however, the negative part of the step response... do you have something that show the summed response of all the drivers?
haraldo
West Norway
The "pre-ringing" is somewhat confusing to me, to me it looks like the woofer and midrange is ringing before the signal should start, but in opposite phase, so I guess ideally they would cancel out .... but I can't get my head around that :rolleyes:
Woofer and midrange is not in the same physical location so I wonder if you will never get a 100% full cancellation, isn't there first reflections that do NOT cancel out (especially in vertical plane), so isn't this audible? :rolleyes:
tuga
Oxford, England
Woofer and midrange is not in the same physical location so I wonder if you will never get a 100% full cancellation, isn't there first reflections that do NOT cancel out, so isn't this audible? :rolleyes:
Are they reproducing the same frequency bands?
haraldo
West Norway
I think so, the wavelength is about 0.0032 seconds, which seems like around 300+ Hz which is exact crossover point between woofer and mid
KSTR
Berlin, Germany
For a linear-phase crossover, the pre-ringing is extremely benign and is most certainly not audible even off-axis where the perfect summing/cancellation falls apart. Note that a typical minimum phase XO's like LR4 have actually more and longer ringing, just that it is post-ringing and that may be more audible in the end as this XO.
In general, symmetrical or coaxial arrangements are somewhat preferable with linear-phase XO's to mitigate the degradation of perfect summing.
Joachim Gerhard
Industry Insider
We like the UB filters the most from a standpoint of soundquality. This is our subjective impression, sure. The result is unique though in terms of micro details and sheer musicality.
Joachim Gerhard
Industry Insider
In my speakers I use quite low crossover frequencies. That also helps the off axis response.
haraldo
West Norway
isn’t there quite many things you can’t measure?
how do you measure the magic of a speaker?
how do you measure a speaker’s capability to bring tears in the eyes while listening to music?
Joachim Gerhard
Industry Insider
I have 50 years of professional experience. I was on at least 300 shows. I was at many famous reviewers homes. I won many test reports and got title pages and interviews world wide. My hearing is intact at 62. In the end i listen. When it sounds bad it is bad, no matter the specs. I work mostly in the time domain. Linear frequency response alone is easy. Every student can do that with modern simulation tools. Measuring off axis and distortion is a good idea too.
haraldo
West Norway
It's what I mean .... I experienced that a good measuring speaker is only good measuring, it doesn't have to be good sounding at all
You certainly convinced me.... I got to listen to ARA before I get my next speakers :cool:
There are several people in the industry that I talked to that say that every design that come from your hands is amazing, so I need to check ....
Sorry if I confused you... when I wrote you in the post above, I did not mean you, but a speaker designer in general :)
Just a sidenote ..... I thought you had your hands on Virgo III, is that incorrect?
Joachim Gerhard
Industry Insider
didin’t you always rely on really low crossover points, especially for tweeters?
Modern tweeters can be crossed very low because they have low distortion down there, much lower then 20 years ago. That is limited by linear mechanics though. In the end is is surface times throw. The UB filters are very steep. That helps too.
Joachim Gerhard
Industry Insider
I think the Virgo 2 was kind of better. Yes, I was the co designer of the Virgo 3 too but curiouslx it was not as successful in terms of sales.
