ninetylol
- Joined
- Dec 7, 2019
- Messages
- 711
- Likes
- 685
Answered before too. TRS.Regarding the rear balanced output (BO) 1/4 jacks do you need TRS or TRRS terminations here?
I was wondering what did you really mean by TRS and TRRS. Perhaps you meant TS and TRS. Make sure it's TRS not TS.So only one ring is necessary. Thank you!
When you buy one tear it down and show us, thanks in advance.I would like to see a teardown with high res photos of the internals. There needs to be more detail on the parts used. What pot are they using? ect
Can it easy drive an Ultrasone 5 unlimited edition, 32ohm 97db? ThanksNot bridged just same wiring. The connectors are just for convenience. But the power is still very high. Designed for He6 and DT880 600Ohm.
Could it be joined with a Matrix mini-I Pro 3 dac? ThanksI was wondering what did you really mean by TRS and TRRS. Perhaps you meant TS and TRS. Make sure it's TRS not TS.
this question been answered. This forum really needs a thread-search utility like Head
Is Matrix a dac+headphone AMP already?[QUOTE = "JohnYang1997, post: 673513, member: 5166"] Mi chiedevo cosa intendevi veramente per TRS e TRRS. Forse intendevi TS e TRS. Assicurati che sia TRS non TS. [/ QUOTE]
Yes sure but has very high impedance so drives with enormous difficult low impedance and sensible headsetsIs Matrix a dac+headphone AMP already?
It's gives the same power 1/4,4.4mm,xlr gives a tad more not much if I'm correct.Heck I don't know. This new 1/4 jack implementation is confusing. None of the cable makers I know of even sell balanced 6.35mm cables. There's never been a headphone amp or DAC that's used this method of inputting/outputting BO audio. This is going to confuse the hell out of people.
L30?You can connect the XLR outputs of the Matrix mini-I Pro 3 directly to the XLR inputs of the L30 using XLR-XLR cables but also from Matrix (using XLR out using XLR-TRS cables on the L30.
Basically the TRS outputs also function as an input as they are simply connected together.
You can't use both TRS and XLR as inputs at the same time though.
I would've not bought Matrix for low impedance phone then.Yes sure but has very high impedance so drives with enormous difficult low impedance and sensible headsets
TRS is 3 contacts though beware. Else it wouldnt be balanced.So only one ring is necessary. Thank you!
So...I use Matrix only as a dac streamer for Roon! I won't use it as a headphone amp. The Topping A30 Pro will be the amp side, do you understand?I would've not bought Matrix for low impedance phone then.
You may consider Matrix Element I which has better output impedance sans balanced headphone output which A30 Pro is lack of either.So...I use Matrix only as a dac streamer for Roon! I won't use it as a headphone amp. The Topping A30 Pro will be the amp side, do you understand?
I've tried it. Mini-I Pro 3 sounds better as a preampYou may consider Matrix Element I which has better output impedance sans balanced headphone output.
L30?
I think A30 Pro it's the best solution for me xlr in A30, xlr out Matrix and so Roon wifi streamingsorry A30
