Topping A30Pro Review (Balanced Headphone Amp)
Wishbon3
Mine was shipped today and gets here the 30th. Wonder how it will compare to my cayin ha-6a.
sweetchaos
The Curator
BC, Canada
Topping (in the past 24hrs) updated their website and released a landing page for the Topping A30Pro:
https://www.tpdz.net/productinfo/590764.html
Their AP measurements show:
Specs and useful info:
:D
Giangi71
Do you have a balanced headphone cable? Do you need preamp function?
I use it eventually with 2xlr 2xlr balanced cable to a Matrix mini-I 3 Pro as a dac but only for headsets. I use often low impedance and medium/high sensible headsets balanced and SE
antony.h
How do I compare this with A90? If my monitors have ground-loop noise issue, are the RCA outputs on A30Pro low noise enough which I do not have to worry about getting balanced output to my monitors?
Any advice and suggestion would be appreciated. Thanks in advance!
bahamot
A30pro has a switch to disconnect/connect the ground, so ground loop won't be an issue.
Racheski
Chicago
I don't think that will affect a ground loop to his speakers; could be wrong tho.
Giangi71
Which main differences between A30 Pro and A90? Which one could be better for me that I use only as a headset amp (no preamp) with mainly low impedance and medium/high sensible headsets with or without balanced? I eventually connect via 2xlr 2xlr the amp to a Matrix mini-I 3 Pro only as a dac. Thanks a lot
Veri
A90 gives you the possibility of true balanced output, and has pre-amp if you later need it. Otherwise A30 Pro is fine, in high gain it'll be WAY too loud for your gear though, so stick to low or middle gain.
antony.h
I have a pair of Fostex Planar T60RP headphone. Would A90 drive them? I need pre-amp function to my active speakers.
Veri
Yes, sure. A90 with balanced input is very powerful. Not a problem.
Racheski
Chicago
Unless you have electrostats, I believe the answer to "will the A90 drive XYZ headphone" is always YES.
Giangi71
I think, however, A90 is better than A30 Pro. A30 Pro is a right compromise, but A90 is A90. But the price...
shinytoaster
The XLR and 1/4 HP out are the same output just a different connector right? So how is amirm getting different results for the distortion vs power @ 300 Ohm? I suppose connector and cable differences could account for the small difference in power but that blip thats only on medium gain on XLR is odd. Not suggesting anything just curious.
Giangi71
[QUOTE = "antony.h, post: 724560, member: 28030"] Non intendo offendere qui. Vorrei sapere perché sei arrivato a questa conclusione. [/ QUOTE]
Because is however fully balanced and has preamp functionality. More power too only for 150usd more
