Lupin
- Joined
- Feb 11, 2021
- Messages
- 589
- Likes
- 981
Why???Hi
I was running the Dynamic range, Quality, Driver matching tests from audiocheck.com on my HE6SEv2, SU-9n and this amp at max gain and max volume. On some playthroughs of the test there would be a click sound that would occur and sound would temporary stop. Did a some more test to determine what was happening as I never experienced this before (typically listen to my music on mid gain 9-10 o'clock). Then I realized that the amp was going into protection mode.
The headphones/amp still sound the same but I am worried that I may have damaged them.
Thanks,
Quote from the website:
Adjust the level in your headphone so that this noise plays loudly, without being uncomfortably loud
There's no way you are going to make me believe max gain and max volume is comfortable audio level with those headphones with the A30 Pro
