<gif>Michael Jackson eating popcorn</gif>
- Can DAC/Amp "optimized" for APx555 but show worse response with actual headphone?
No. Square waves / impulses don't make sense for sound. If THD/IMD is ok I don't know why you'd take a look at squares. Is there an explanation for this test? And for Topping's advertising?Do we need perfect square wave on Amp (not DAC) like sine wave?
There are no reviews out of the product, other than this one*. Which is sad. It's a promising product for sure.Anyone have a video or link to a video that shows the screen in action? You'd think a product with a screen with digital meters would be easy to find examples of it in motion.
I know real world does not have square waves, but topping's material is a bit confusing me.No. Square waves / impulses don't make sense for sound. If THD/IMD is ok I don't know why you'd take a look at squares. Is there an explanation for this test? And for Topping's advertising?
I found no videos too, only pictures.Anyone have a video or link to a video that shows the screen in action? You'd think a product with a screen with digital meters would be easy to find examples of it in motion.
Upload it to YouTube, set the video to unlisted so that only those with the link can find it, then post the link here.I made a quick video of my own device, but I don't know how to insert it.
Exactly what I wanted to see. Thanks!
Wait till DX9I'm using Topping DX7 Pro+ currenctly and consider to upgrade, this looks attractive so I'm checking reviews about it.
I don't hear any distortion. Alison Balsom - Caprice. No distortion, but I will test it on wilder music and write about it. I'm falling now, she has such a beautiful voice! More low notes, punchier, faster. Requires a silver cable.Hi, anyone who has this amp getting distortion ?, i am getting it on the right channel on some music at higher volumes.
What sort of volume are you listening at?I don't hear any distortion. Alison Balsom - Caprice. No distortion, but I will test it on wilder music and write about it. I'm falling now, she has such a beautiful voice! More low notes, punchier, faster. Requires a silver cable.
Maybe yours is broken.Hi, anyone who has this amp getting distortion ?, i am getting it on the right channel on some music at higher volumes.
Low gain, -28 cB. The volume also depends on the music. The volume also depends on the music. Classical music requires more volume for the same sound pressure.What sort of volume are you listening at?
You can do a simple test, try swap the headphone connector (if your headphone has dual connectors), if the left channel start distort after swap then it's on the amp, if distortion still at right channel then it's on your headphone.It’s definitely the amp as have just tried another and it’s fine
Yes though I don't know why topping start putting orange LED in their new amps (EHA5, DX9), maybe it can make the sound warmer.Wait till DX9
