Topping A70 Pro HP & Preamp Review
Rate this preamplifier and headphone amp:
    Votes: 14 4.2%
    Votes: 7 2.1%
    Votes: 37 11.0%
    Votes: 278 82.7%
enricoclaudio
Houston, TX - USA
Slightly different specs from the Pre90, but it also has the headphone amp and the display to help out with seeing what's going on.
So, at this price point what is advantage of ordering the pre90?
Currently, I don't see the advantage on ordering a Pre90. If Topping has an update for the Pre90, D90SE and A90D in the works, then most likely that would be the one to get instead of the current Pre90.
1122333
A70pro sounds excellent, it is a non dyed, transparent, and stretchy tone.
Secondly, I must give a thumbs up to its Preamplifier. I can't hear any difference between plugging the speaker directly into the DAC and the A70Pro, just like it doesn't seem to have passed through this device....
Veri
Wire with gain!
Music1969
I really wonder about this, too.
Nothing to wonder - other than its sexy looks, I can't see anything where A90D is better
Looove that dot matrix display for volume.
Unique , stands out as different
But A70 Pro beats it in everything else
jruser
Can you test the range on the remote for us? That was an issue with some past Topping products.
jruser
So, if you use the Ext90 with this, do the extra inputs also have the higher impedance? Or does the Ext90 have its own impedance?
jdan1457
How does an end user get the 12.6w at 32ohm out of this amp?
Is the reason Amir's measurements not as high as theirs because he's measuring at lower distortion?
Do amps in daily use somehow produce more distortion and reach more power?
I just don't get how they can claim that level of power if a person can't actually reach that in daily use.
Edit: I guess a better question would be under what conditions does the distortion and power increase to reach the 12.6w?
staticV3
Take the Amp out of the box, give it power, plug in a DAC and Headphone, and turn up the volume.
No special configuration is needed to get 12.6W at 32Ω.
Yes.
No.
But a person can reach that in daily use.
High enough input voltage + high enough volume on the Amp.
jdan1457
I guess I really just thought that I was gonna read Amir's review and it was gonna be 12.6w. The numbers for the A90D and L70 were the same/close enough to their marketing but this one isn't.
staticV3
What is max input voltage of this amp?
I don't know. Probably 9+ Vrms.
The only person I know who tests max input voltage is @nagster
See:
raif71
Yes.
No.
Can a headphone with rated 32ohm be able to withstand the full 12.6W ?
Sray
I think the ext90 should be just an input switch box controlled by main box. The main input stage should be reside in A70Pro itself.
The guess is because performance doesn't change between main input and ext90.
staticV3
@Sray @Music1969
What Topping calls Input sensitivity is the voltage required at the input to clip the Amp's output with the Amp at 100% volume.
You can reduce the Amp's volume and feed it higher voltage than what that sheet says.
For example, According to Topping, the L70 in High gain has an input sensitivity of 1.9V:
Yet, if you reduce the volume so that the output doesn't clip, then you can input up to 10.4V with the Amp in High gain:
Atanasi
@Sray @Music1969
The low gain balanced sensitivities are probably close to the limit of the balanced inputs. When the amp is internally single-ended, balanced inputs go through op-amps before attenuation, and these op-amps have voltage limits. Single-ended inputs, on the other hand, can be attenuated as they are and can take higher voltages.
