Topping A90 Discrete Review (Headphone Amp & Preamp)
Rate this Headphone Amp/Pre-amp
    Votes: 16 3.9%
    Votes: 14 3.4%
    Votes: 70 17.2%
    Votes: 306 75.4%
tritopia
Hows the noise floor in Single Ended and Balanced on sensitive stuff?
Volume levels (00-99) below 30 sound very low. When it gets smaller, it becomes a subtle sound and then becomes as silent as darkness. At first, I set the default volume to 10, but I was shocked to find out that it didn't work. Changed the default volume to 30.
Today, I am only listening to the sound with a preamplifier through XLR input/output.
I'm using two studio monitor headphones, both of which are connected via unbalanced 6.35 jacks.
The sound is... the sound of the topping. Accurate, transparent, and silent.
We don't have headphones that support balanced, so it's impossible to test it right now. please understand. ;)
carlcamper
Cavite, Philippines
Thanks. By noise floor I mean is there any hiss?
carlcamper
Cavite, Philippines
No noise is heard.
It doesn't degrade the DAC's Sinad level, and it doesn't impute any noise to the power amp.
Great to hear! Mine is due to arrive on July 4th, can't wait to test it on my sensitive IEMs
Haruko
now I'm glad I didn't buy A90 right away and waited for this
tritopia
I found one thing I didn't like.
The gap between the AC plug and the 12V trigger plug is narrow and interferes with each other.
Considering that the jacks on the 3.5 cables I use are slim, thicker ones will get in the way more.
Of course, there is no such interference with the bundled AC cable included with the A90D. It's a problem with the AC cable I'm using, but it would have been better if the terminal layout was slightly changed.
I removed the cap of the 3.5 terminal and am using it without any problem, and of course the function works very well.
Actually nothing is a problem. ^^
enricoclaudio
Houston, TX - USA
As proved by @amirm in several tests, there is no need to use fancy power cables as they do not improve SQ or anything. Good engineers know that and that's why the layout Topping used is correct ;)
enricoclaudio
Houston, TX - USA
mocenigo
So....why aren't Marantz delivering this level with their HDAM receivers and processors (or at least matching benchmark performance for that class of product)?
Incompetence?
Carelessness?
They just do not care.
pma
Prague
I appreciate that there a are no high order harmonics visible in the spectrum of the discrete A90 version, compared to the one with IC's. And also the cleaner noise bottom.
Topping A90 Discrete Measurements Headphone Amp Preamplifier Balanced.png Topping A90 Headphone Amplifier Unbalanced Audio Measurements.png
Haruko
View attachment 215560 View attachment 215561
idk if it's time rounding difference but look at the grass at the bottom ... it looks much more flatter on A90 discrete
enricoclaudio
Houston, TX - USA
That's because relay stepped volume controls behave logarithmically and not linear like pot volume controls. It took me sometime to get used to the stepped ladder volume control on my Parasound Halo P6 but the benefit of having perfect channel balance is worthy.
mocenigo
I think you have swapped linear and logarithmic.
Atanasi
Stepped attenuators can be made with any steps. According to this thread, A90D maps the 0-99 scale to dB such that the highest steps are 0.5 dB apart, the middle ones are 1 dB and the lowest 2 dB.
mocenigo
This is true but this one is made as an R2R chain, IIUC, which is by definition linear. However, the controller skips (i.e. does not map) some steps at the intermediate and lower levels.
mrjayviper
recommended dac to pair with this amp? (I often see in aliexpress seller selling a combo of this amp + D90)
thanks in advance
Rottmannash
Nashville
Is this why on the Schitt Frey+ the volume seems to jump exponentially the higher on the scale I go? Everything's chill until about 2 o'clock then each click is an enormous increase in volume. Or is it my imagination?
