This is a review and dd measurements of the Topping D50 III balanced stereo DAC with support for parametric equalization.
I agree. Ever since I found out about intersample overs and since I've measured a load of my tracks for intersample overs I worked out that most tracks fell within the bracket of up to +2dB peaks intersample overs with a few just a little above, so I always put in around -3dB extra on the negative preamp (on top of what's required for an EQ) to ensure no intersample overs get through. I suppose the beauty of this measurement you're suggesting means that if you get the right DAC that can deal well with intersample overs then you wouldn't need to go to the trouble of putting in a -3dB negative preamp to avoid potential intersample overs, which means more power available and a bit better SINAD.It would be nice to add intrasample overage measurements with all DACs moving forward, like those provided by Rja4000.
- Rich
Obviously. 5v out. But I doubt it's needed.so what about the topping p50 power supply. can that one be used?
Sure. It just won't do anything that a phone charger can't.so what about the topping p50 power supply. can that one be used?
Fair point. But we don't want to rely on unofficial measurements in the long run. Also, it kind of proves my point that @Rja4000 found it to be a good idea to include such a measurement. However, in the official version, it should be standardized - same as other measurements are.If I can understand what you are saying,you can see some measurements about what you want in the other review (just before the end of the review) of D50 III here:
(Unofficial) Topping D50 III DAC review and measurements
Here is a review and measurements of the recent Topping D50 III DAC The D50 III is a small DAC. From above, it looks like a square of approx 13x13cm . I purchased it new from Audiophonics for around 230€ (pre-release discount included). This is one of the cheapest DACs with balanced and...www.audiosciencereview.com
Agreed,we want to rely on reliable measurements.Fair point. But we don't want to rely on unofficial measurements in the long run. Also, it kind of proves my point that @Rja4000 found it to be a good idea to include such a measurement. However, in the official version, it should be standardized - same as other measurements are.
Of course not,if it did something really strange would be at play.Is the PEQ also supported by DSD Inputsignal?
Does it mean people can’t tune the EQ if don’t have Windows PC?You can store multiple PEQ presets on the D50 III, and they can be used without Topping Tune running in the background.
That way, you can for example configure the PEQ on a Windows PC, then use it on a Mac.
Adding device is not a solution.Wait. The PEQ is not implemented in the driver for the Windows PC but somewhere in the box? If so, why not apply it to S/PDIF in, too? In order to use it, one would need to buy an additional S/PDIF to USB device, which seems superfluous.
Now can we have the PEQ (ideally including LP, HP, shelving) in a multichannel DAC such as a successor to the DM7 please?
You mean device = cheapo S/PDIF or optical to USB out? If the PEQ is indeed implemented in the XMOS, it should work.Adding device is not a solution.
Presumably they are routing the coax and toslink direct to the DAC chip's spdif input, rather than via the XMOS. That's what Khadas did with the Tone Board. IIRC the XMOS can be used as an spdif receiver, so it seems like a design choice. It could be as simple as deciding to add the PEQ late in the day, after the hardware design had been done.Wait. The PEQ is not implemented in the driver for the Windows PC but somewhere in the box, presumably the XMOS? If so, why not apply it to S/PDIF in, too? In order to use it, one would need to buy an additional S/PDIF to USB device, which seems superfluous.
For sure ? But then the PEQ isn't suitable as a room correction if it doesn't work with all signals. Could it be that it converts the signals to PCM?Of course not,if it did something really strange would be at play.
I surely hope not.Could it be that it converts the signals to PCM?
It will. It. akes me feel coolSure. It just won't do anything that a phone charger can't.
