Topping DM7 8-Channel DAC Review
Rate this DAC:
    Votes: 7 2.2%
    Votes: 18 5.6%
  • 3. Fine (happy panther
    Votes: 52 16.2%
    Votes: 244 76.0%
jtwrace
Orlando, FL
It would've helped Topping to actually send units to beta testers that use these configurations. I mean; it's no secret of who was requesting features for a MCH dac like this from the thread I started here on 9/21/2021. This in my opinion was a fail.
Reactions: MAB
phoenixdogfan
Nashville
Unless you have a spatial setup. 2D surround is very last decade :)
Not to mention you don’t have HDMI inputs nor selection.
If you have the room and the wallet for a full on Atmos setup, go for it. Most people will probably be doing 5.1 or 7,1. Me, I do 5.1 over the PC, and view Atmos movies over my SMYTH A16 Realizer which does up to 24 immersive audio channels of ATMOS, DTS-X, and/or Auro 3D over my choice of in studio recorded Dutch & Dutch 8Cs + Pardigm sub PRIR or my home recorded 24 channel LS 50 Metas with SB 2000 sub PRIR binaurally rendering out to my HD 800s and LCD Xs.
monkeyboy
They could come out with the required bridging device, probably HDMI eARC to USB then you could put your PC in the middle and do your DSP...
manisandher
Royal Leamington Spa, UK
It would've helped Topping to actually send units to beta testers that use these configurations. I mean; it's no secret of who was requesting features for a MCH dac like this from the thread I started here on 9/21/2022. This in my opinion was a fail.
9/21/21 ;)
Perhaps this is just the first multichannel offering from Topping? In which case, I think it's a pretty good attempt... for the price.
Mani.
jtwrace
Orlando, FL
9/21/21 ;)
Mani.
Ha, yes, corrected. I try never to go backwards in life. ;)
voodooless
Netherlands
A HDMI capture card might get you there, but you have HDCP to deal with. You’ll probably won’t get bitstream audio out of it.
sarumbear
Yes, thanks! We are screen capturing the same website just so you know!!! And seeing the same drivers on that website. The same owner's manual.
Then why are you asking what is in front of your eyes?
I’m responding to your following post. As Amirm is talking about driver, the word “this” and “it” in your post means drivers too. I was trying to be helpful by telling you to refer to the manual which clearly says “it” is in their website.
Reactions: MWC
levimax
San Diego
Suppose I have the above configuration:
1) USB connected to PC and running Foobar2000
2) connection to active speakers as above
Does Foobar 2000 have channel assignment such as above or similar (the numbers above are just for reference)? What about SW cutoff frequency setting? Does Foobar2000 have cutoff freq setting?
Check out foo_dsp_xover http://xover.sourceforge.net/
Music1969
Well, yes - I'm definitely familiar with the disappointments associated with Linux audio. But, in the overwhelming majority of cases I've looked at, it's the mixer/routing/channel mapping that tends to be the problem with these interfaces.
There are way more pro audio interfaces that do have issues with Linux + multichannel, than don't
There are a few Motu models well known to play nicely with Linux
But spend some time at Linux Musicians Forum to see all the issues
I'm specifically talking multichannel on Linux
We don't yet know about DM7 with Linux
Reactions: MAB
dualazmak
Then have you read and participated in @dualazmak 's very comprehensive discourses on active crossovers for his speakers using an 8 channel DAC ?
Thank you @maxxevv for your kind description about my active multichannel multi-amplifier project using OKTO DAC8PRO.
Those who would be interested, you will be much welcome to my thread on multichannel multi-driver multi-way multi-amplifier stereo audio project. You can find my latest (as of May 30, 2022) system setup here. You would please find here (on my project thread) and here (remote independent thread post) the Hyperlink Index of my project thread.
Reactions: MAB
Sokel
For simple channel mapping you don't need plug in:
but yes,foo dsp xover has everything one needs.
Edit:For everyone who wants to play with multichannel SACD's:
Peafowl
Germany
Multiple inputs is not the point. If it had parity with OKTO in that regard you would for example be able to use a CCA as a source into the DAC, send to USB host for crossover DSP processing, and back to the DAC and feed into amps and have a clean active DSP speaker setup with no additional ASRC in the chain.
If you are looking for a all in one solution ... there you go https://analog-precision.com/home/upp/
But don't say it is to expensive because otherwise you would need 2-4 different hardware and software units to do the same thing.
sarumbear
Peafowl
Germany
Hi I canot see the benefit of this example, because you create an multi ADC ,DAC chain. Attched the Hypex block diagram. This explains the internal Hypex structure.
Please help me to understand your example.
They talk about "DIY" multi channel hypex Amps not the plate-amps which includes an extra DSP.
Timbo2
USA
Make me spit my coffee out! LOL.
The one that really got me was a JVC Super Digifine receiver, RX-1001V. I think it's around 100 buttons (many double ended) on the moulded back plate, under the front panel buttons and above the tactile switches. And every one, perfectly centred, supported and positive. Ahh, the 80s.
It was a retro beast. I have one someplace- you should see the remote! Full backlit touch screen LCD learning thing.
I had one of these in college. We referred to the backlit LCD as “Tokyo at Night”.
sarumbear
An UX nightmare. The UI is designed on a grid paper! :eek:
