Topping DM7 8-Channel DAC Review
Rate this DAC:
    Votes: 7 2.2%
    Votes: 18 5.6%
  • 3. Fine (happy panther
    Votes: 52 16.2%
    Votes: 244 76.0%
charlielaub
I think you would agree that converting between AES / TOSLINK / SPDIF is rather trivial with inexpensive off the shelf devices? Which pro audio interface are you using that has a word clock input but cannot be clocked by AES or SPDIF input? And again, if your ADC has a digital output you can feed that in to the AES input of the Okto and Okto will be slaved to the ADC.
I just can't think of case where you need a word clock input where AES / SPDIF won't do.
Michael
I thought about this overnight. Assuming (making a leap here) that the interface with ADC has an AES-EBU input you are 100% correct. It is something I never really considered and an interesting way to slave two interfaces.
The AES-EBU and SP/DIF audio format is identical but AES-EBU is much less common than SP/DIF. These formats are not identical nor directly interchangeable, with different signal levels and different termination impedances. Do you know of a reliable low-cost converter from AES-EBU to SP/DIF?
Hertel
Thank you very much
I knew it's just a DAC, not having DSP filtering features like the MiniDsp Flex. Precisely for this reason My question was whether the DM7 associated with a PC and a software like Equalizer APO could produce a stereo sound with two subwoofers. In this case, two channels for subwoofer with low pass filter and two channels (left and right) with high pass filters.
From what I understood from your answer, this is possible as long as the DM7 is in conjunction with a PC, right?
charlielaub
Thank you very much
Yes, but the question really has nothing to do with the DM7. The DM7 is just converting the digital audio that the computer gives it to an analog signal. So yes, given the right software and computer configuration you can do it, but your focus should really be on how to do that on the computer and not on aspects of the DAC itself. Also keep in mind that this is a balanced DAC and you should not use it to drive unbalanced amplifiers (e.g. with RCA inputs). If you have only RCA connections, use a different DAC.
mdsimon2
Detroit, MI
In practice they are very interchangeable. Most devices work fine with a simple RCA to XLR cable but a few need transformers.
For the Okto specifically I've used the AES output in to a Neutrik NADITBNC-FX transformer in to variety of SPDIF input devices ranging from audio interfaces (MOTU Ultralite Mk5, RME Fireface 800, MOTU Traveler Mk1) to cheap consumer TOSLINK to USB cards like the hifimediy offerings (through a coaxial to TOSLINK converter).
I've also used Neutrik NADITBNC-M and Canare BCJ-XP-TRB transformers on SPDIF output devices for use with the Okto AES inputs as well.
Michael
Hertel
Sim, mas a questão realmente não tem nada a ver com o DM7. O DM7 está apenas convertendo o áudio digital que o computador lhe dá para um sinal analógico. Então, sim, com o software correto e a configuração do computador, você pode fazer isso, mas seu foco deve estar em como fazer isso no computador e não em aspectos do próprio DAC. Lembre-se também de que este é um DAC balanceado e você não deve usá-lo para alimentar amplificadores não balanceados (por exemplo, com entradas RCA). Se você tiver apenas conexões RCA, use um DAC diferente.
Thanks again for the reply
My amplifier (SMSL AO200) has both balanced and unbalanced inputs. However, my subwoofer pair (Kef Kube12) only has an unbalanced input. I think in this case it would be a problem
Does the MiniDps Flex in its balanced version have the same problem as the DM7? If so, my last option would be the unbalanced MiniDsp Flex
Kal Rubinson
Industry Insider
NYC
I cannot say for sure but I believe that the digital input is only used for a clock source when it is the selected input
Sure but what digital input are you talking about?
Kal Rubinson
Industry Insider
NYC
Did this support 24/192?
edechamps
London, United Kingdom
In theory, yes.
In practice, the channel mapping will be a bit of hack because you'll have to lie to Windows and tell it you have a 5.1 device, otherwise you won't be able to output 4 channels from an APO. This means applications will believe you have a 5.1 output, and might try to output 5.1 audio, even though you only have stereo. This might lead to sub-optimal results and force you to downmix in Equalizer APO first.
Kal Rubinson
Industry Insider
NYC
I’ve only done it at 48 and 96 kHz as a lot of interfaces don’t support 192 kHz. I’ll test 192 kHz and let you know how it goes.
Michael
I am planning to take the AES/EBU output from my Merging Hapi II to feed a KEF LS60 which accepts S/PDIF or TOSLink. This might help. I am also considering the Hosa ODL-312 or ODL-313 but these are specified only up to 24/96.
nagster
I couldn't find Neutrik, but I found CANARE BCJ-XJ-TRB, so I tried 24/192.
Although it was a simple verification, there was no strange behavior.
AP =>conversion transformer =>AP
nagster
AP =>conversion transformer =>DAC =>AP
dualazmak
EDIT: Since content of this post is not related to Topping DM7, I hided it under Spoiler cover. I thank @dartinbout for kind chiming and reminder.
If the delay and sound quality (as well as gain) would be acceptable/adjustable, then the "headphone analog RCA out" of a multichannel DAC (like OKTO DAC8PRO) can be used feeding "unbalanced input only" subwoofers. I actually use this path for my L&R subwoofers (large and heavy Yamaha YST-SW1000, L & R) in my DSP-based multichannel multi-SP-Driver (actually 5-way 10-Ch) multi-amplifier fully active audio setup; you can find the latest my system setup here.
dartinbout
Just out of wild curiosity, why is all of this Okto discussion not in the various Okto threads? I had the Dac8 Pro, sold it and bought the DM7. For my needs and wallet, it fit my love of surround and HT better.
dualazmak
EDIT: Since contents of this post are not related to Topping DM7, I hided them under Spoiler cover. I thank @dartinbout for kind chiming and reminder.
Yes! AES/EBU digital output always contains sync clock signal for the slave gears.
And, in other way, if AES/EBU digital out of OKTO DAC8PRO is fed into AES/EBU input capable device (like AES/EBU input DAC unit) the device is automatically will be slave (synced) with DAC8PRO.
I fully confirmed this path using ONKYO DAC-1000 which has AES/EBU digital input; please refer to my post here and here.
Furthermore, in his post here, Pavel of OKTO RESEARCH kindly confirmed the AES/EBU digital sync connection from DAC8(PRO) to another DAC (capable of AES/EBU digital input) as well as to any other gears having AES/EBU digital-in.
dartinbout
Please help me oh wizened ones, where exactly to I plug my AES\EBU into my DM7? Is there a special cable I need? Is it perhaps on it's derriere? Do I need to dissemble it and break out my soldering iron? How about vacuum tubes? Is there a phone stage? Is there some special button push to make it play "God save the Queen" on continuous loop? Please keep this thread on topic please as I don't need anymore notifications not germane to the DM7.
dualazmak
Fully understood, and I am sorry for my above two posts not related to DM7; I hided the contents under Spoiler cover.
192kbps
Multichannel ASIO Renderer 3.8 Trial / 2.0 Free
First of all, you can always switch cables until your channels match your speaker locations.
But you can also use MPC-HC or ffdshow, and do pretty much what you want with audio:
View attachment 263630 View attachment 263631
ffdshow in particular would allow you to quantize values (e.g. 50% of Center to the Front Left and 50% of Center to the Front Right).
Maybe there are other solutions, I don't know.
Multichannel ASIO Renderer?​
