Most audiophiles can't tell the difference between 256KB/s MP3 vs uncompressed music and also most cannot even tell the difference between a modern built in pc motherboard soundcard vs expensive Dac and Amp at the same volume. Don't overthink.In general
Which option is better (better quality)
Low gain and volume level around -30
Or
High gain and volume levels around -50
Theoretically the first one, in practice dreamscene might be right, or not (if you can hear noise)In general
Or
it replaced my motu m2 interface+liquid spark stack if you can call that a stack i guess. I genuinely think the dx3pro+ sounded better plus BT more power and way cheaper.in my opinion it does not beat a dac+amp combo, but let's see what you say.
Hi there, I wonder if my Sennheiser HD595 are considered "low impedance headphones" and if I thus must avoid the Topping DX3 Pro+. I can't be sure but I think I have the 50ohm model (the first series of HD595 were 120ohm). Thanks!It doesn't have infinite capability as far as low impedance headphones are concerned so for that, you need to step up to myriad of other options from Topping.
I also have liquid spark. In my opinion, dx3+ in DAC mode connected to Liquid Spark as AMP sounded smoother and more natural that dx3+ headphone out. If you try it out, make sure you put the volume to 0 db.it replaced my motu m2 interface+liquid spark stack if you can call that a stack i guess. I genuinely think the dx3pro+ sounded better plus BT more power and way cheaper.
I'm such a newbie I can't properly read those graphs.Does it though?
The clipping points are at the very end. Performance is very good right up to the point where it runs out of juice..I'm such a newbie I can't properly read those graphs.
So I should avoid the Topping having 50 omhs headphones? I also considered the Fiio K5 Pro MKII but I read the Topping is quite superior in almost every aspect.@raistlin65
Then how do you explain the extra power that WolfX-700 saw on his unit?
I can see how Amir's results may stem from low resolution (high step size) + long enough test duration for each step to make the DX3Pro+ overheat, causing early clipping.
I can not see how the DX3Pro+ could trick Wolf's APx555 into seeing more power than it is actually capable of.
Edit:
I plotted output voltage @knee vs load for both measurements:
Which one looks like the Amp's actual performance I wonder
No, I don't think you should avoid the DX3Pro+.So I should avoid the Topping having 50 omhs headphones? I also considered the Fiio K5 Pro MKII but I read the Topping is quite superior in almost every aspect.
@raistlin65
Edit:
Thanks a lot, I will get the Topping. One last thing: what kind of improvement can I expect coming from an Asus Xonar Essence STX (the first series)? Will the improvement be noticeable?@davidrf For example:
The HD595 has an impedance of 55Ω and a sensitivity of 115dB/Vrms (as measured by Solderdude and innerfidelity).
At 55Ω, the DX3Pro+ can put out about 7.9Vrms before clipping according to measurements by L7.
That means that it could theoretically drive the HD595 to about 133dB SPL (in reality, the headphone will reach Xmax far sooner).
Listening at that volume would give you permanent hearing damage real quick.
-> Even the A2049 Apple headphone dongle has enough power to drive the HD595 to very loud levels. The DX3Pro+ has absolutely no issues with that headphone whatsoever. It can provide enough voltage to probably destroy the headphone along with your hearing.
