staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,065
- Likes
- 12,971
I can't make such a prediction.Will the improvement be noticeable?
Volume encoders on the DX3 Pro V2 and Pro+ feel the same to me and I have not had any problem with either.Can anyone comment on the volume knob of the DX3 Pro+? How does it compare to the original? Satisfying clicks with accurate response? (That is not double stepping or skipping volume?)
Also are there siliencing relays on this unit? Or at least no audible thud through the amp/speakers when the unit powers on/off?
Thanks a lot, I will get the Topping. One last thing: what kind of improvement can I expect coming from an Asus Xonar Essence STX (the first series)? Will the improvement be noticeable?
Thanks. Damn from that measurements the STX II is so bad it almost can't be true...Review and Measurements of Asus STX II PCI Sound Card
This is a review and detailed measurements of Asus STX II PCI Express sound card. It is on kind loan from a member and retails for USD $219 on Amazon including Prime shipping. Full list price is $299. This is a medium sized PC card which oddly requires external power. You can see it here...www.audiosciencereview.com
@Ordered a dx3 pro+ and a sennheiser 560s. Looking forward to my first non cheapo headphone setup! Thanks @amirm for making this easy for us
It's going to be fixed/replaced by the manufacturer, or the merchant?Unfortunately, my Topping malfunctioned a few days ago One of the display segments doesn't light up. I'm going to get it fixed/replaced.
As for the sound - I like it very much. I can't tell any difference between E30 and DX3 Pro+ in a blind test (not that I should, given the top-class measurements).
The seller told me to send it to the Polish distributor.It's going to be fixed/replaced by the manufacturer, or the merchant?
Same problem for my brand new unit ! But I don't care as it sounds so amazing !!!Unfortunately, my Topping malfunctioned a few days ago One of the display segments doesn't light up. I'm going to get it fixed/replaced.
The T1 3rd Gen is a very efficient headphone. With the DX3Pro+, you will clip the drivers of the headphone far sooner than you could ever clip the Amp.Would this be good pairing for Beyerdynamic T1 3rd gen (32 Ohm) ? No clipping issues?
Nice, have not seen that error thought but i dont play loud or have demanding headphones. Will wait until some ppl in this thread can confirm the update works without issue until i update.There is a firmware update for version V1.23 of DX3 Pro+. Headphone users should update.
What's updated:
Fixed an issue where the built-in amp overload protection was too sensitive to prompt "HP ERR" under certain circumstances.
Update would not open on my Mac (M1 Air). Will try with a Windows laptop later.There is a firmware update for version V1.23 of DX3 Pro+. Headphone users should update.
What's updated:
Did you download the file for the MAC?Update would not open on my Mac (M1 Air). Will try with a Windows laptop later.
